Old 09-29-2003, 12:22 PM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
Differences between '73-'87 front crossmember and '67-'72 ??
What are the main differences between the front suspension crossmember on a '73 - '87 1/2 ton and a the older '67 - '72 trucks?
Mainly I am wondering about the mounting points of the lower control arm. Do the newer style trucks use U clamps to mount them like the older one I have?
I already know the newer one will bolt in, and the newer ones use larger rubber bushings and such. Can I use a newer style lower control arm in my '70 crossmember?
Thanks for the help!
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 09-29-2003, 09:26 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
It should bolt right in from what I have read here. I have a 83 and ordered a notch crossmember from turner enterprises in California and he sells mainly 67-72 parts. It will work.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-30-2003, 12:26 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Differences between '73-'87 front crossmember and '67-'72 ??
Yes, they bolt right onto the older crossmember, both uppers and lowers. The later lowers mount with the little u-bolts just like the 67-72 ones.
Kevin
Old 03-31-2004, 12:40 AM   #4
72c5
72c5's Avatar
What about the crossmembers? Will the '73-'87 bolt into a '69 frame? I want to get rid of the leafs in a '69 blazer.....
72c5 is offline   Reply With Quote
