Old 05-15-2016, 02:14 PM   #1
chrismoore701
chrismoore701's Avatar
Axle seals leaking
I just installed the axle in my 79 after sitting for many years. The front seal and one axle seal leaks. Can I get away with a stop leak additive? If so for how long? No problem on pulling it apart and replacing seals. But don't want to do that until this winter
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-15-2016, 04:19 PM   #2
Jake Wade
Jake Wade's Avatar
Re: Axle seals leaking
I would not do the snake oil, fix it right.
Jake Wade is offline   Reply With Quote
Old 05-15-2016, 06:01 PM   #3
Dead Parrot
1. Long distance daily driver or occasional use only?
2. A few drops on the ground or half a cup?
3. Are you ok with doing frequent pull the plug oil level checks?
I see no problem with stop leak as long as you plan on seal replacement fairly soon. Think of the stop leak as a scheduling aid, not a long term fix. The seals probably hardened during the down time and cracked when the axle was returned to service.
Dead Parrot is offline   Reply With Quote
Old 05-15-2016, 06:29 PM   #4
chrismoore701
No drips. Just sprayed on bottom of bed. Just occasional use. Looking to get to winter and tear it down then
Chris
