70+ ( Old Skool Club )
![]() Join Date: Nov 2003
WTB Cowl to Vent Door Spring
I need the spring that comes on A/C trucks that goes from the cowl to the vent door.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#2 | |
![]() Join Date: Apr 2013
Re: WTB Cowl to Vent Door Spring
If it is the one for the vent door in the kick panel I have that one too I believe. Let me know. Jay |
Its the spring that goes from the cowl to the vent door on the right side under the cowl. I think you have confused me with someone else because I don't think I have ever bought anything form you.
Sorry, I saw vent door spring and Canada and did confuse you with another person I sent one of these springs to. Jay
Bump
![]() Join Date: Aug 2013
I'm pretty sure I have one. I'm traveling but when I get home l'll check and let you know.
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
Thank You.
Well, turns out, I didn't have one. Sorry. Hope you find what you need.
Thanks for looking
I just bought a bunch of parts from a 1972 C10 that a guy parted out. It had A/C and I think when he showed me the boxes of loose parts that I might have seen one in there. I didn't post sooner because I thought you had one located - wanted to give other person first shot.
Also, it would be "bragging rights"?? to be able to claim I sold two springs to people in Canada. hahaha |
#11 | |
#13 | |
![]() Join Date: Jan 2010
#14 |
#15 |
Thanks for looking Jay.
#16 |
Bump
#17 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Maybe a hit here Greg? I will likely need one or two myself: http://www.thespringstore.com
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#18 | |
#19 | |
![]() Join Date: May 2010
Hmmm... I still have the one in Greg's picture but it's in use in my truck. I think I also have my original somewhere, but one of the hooks broke off. I bent the broken end to work. I also have another, but it is broken in the coil portion. I may be able to use the 2 broken ones and the additional pictures in my file to spec out a suitable replacement. It'll probably take some time though. I've thought about having some reproduced. Maybe the place in your link would be a less costly alternative. The toughest part would be determining the "spring rate". I wonder how big the market here would be. Jim |
#20 |
This place is 16 miles from me. Maybe I should pay them a visit!
Jim |
#21 |
#22 |
A form member sent me one earlier this year. It was a little rusty but looked ok, well when I went to pull it to install it the hook broke off. Found one at lowes that works. Not quite as thick of wire but it does the job.
Keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#23 |
![]() Join Date: May 2015
I bought a variety pack at NAPA for about 5 bucks, I was able to make one work. If it doesn't have to be a GM this worked pretty well.
#24 |
Thanks for the tips. I'l try Lowes and Napa here but know they don't always carry the same things as the stores in the USA.
This place is 16 miles from me. Maybe I should pay them a visit! Jim Jim if you go the the last and they can't help you with spring maybe you could get plant tour and that would be interesting to see how springs are made.
#25 |
If you go the NAPA route and your's does not carry them, let me know and I will pick a pack up for you.
