91 SWB 383
for sale set of 882
they have 194/150 in them and they need to be clean up . will take 50.00 for the set . will take trade for motor parts
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
MY TRUCK IS FOR SALE!!
Hey kevin,
Whats a set of 882?
1979 Chevy LWB 350ci / 700R4 Edelbrock under the hood F O R S A L E OR T R A D E ![]() |
I assume they are small block heads ending with the casting numbers 882, comonly refered to as 882's
Yup, that's what they'd be. 882's are pretty common "emissions" heads if my memory serves me correctly.
Brian |
91 SWB 383
the emissions i don't know about . the rest u r right . they r good go fast head . the need little work to flow good. they like 170 or 180 cc runner . they work good for performance motor .
91 SWB 383
Are they the heavy casting 882 or the light? The light casting seems to crack bad.
Chuck '85 Chevy Silverado 4X4 ![]() '91 Chevy 4X4 Suburban ![]() http://www.cardomain.com/memberpage/545941 |
91 SWB 383
i only know of one 882 head . none of my book show anyother 882. so don't real no how to answer the question .
would you be able to ship? If so, would it be safe so they wouldn't get damaged? Let me know.
Thanks, - Ben
Ben 84 C10 Silverado 14 Silverado Z71 |
driving is in my blood
All 882's are emissions heads with 76cc chambers and about 160cc intakes, and are all light castings.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
91 SWB 383
i was think they where 170. thought it was close . yes i can ship. if u pay shipping
91 SWB 383
the intake runner make them a good flow head for low $$$$$$$$$$$
#13 |
yup, open chamber 76 cc, 160cc intake runner smog head. They're light castings but not as light as the troublesome 462624s that are prone to cracking. They do have a reasonable flow on the intake but the chamber design makes it that they're not real performance heads, just nice. All in all, open chambered heads suck
#14 |
882s were made in both castings.
The 74-75 were the heavier castings and in 76 GM went to the lighter castings. Easiest way to tell is around the spark plug holes. ''Heavy'' heads are cast straight below the spark plug bosses,where light heads haves 'scallops' below the plugs. Virgil |
#15 |
91 SWB 383
if that true . then they r the heavy .
#16 |
Could I just drop them on, or would they need new seals? Fit an '83 K5 with 350?
#17 |
91 SWB 383
that would be up to u . i would have them cleaned up at a shop . they have no cracks . they have been check for that before i bought them . i went with a set of AFR HEADS. they fit any 350
#18 |
Thank You 44th MISS INF.
I have 3 sets of these heads and ended up with 3 of each type of casting. They also have both 1.72 and 1.94 intake valves. Have 3 each of these also. The missmatch set was on my truck when i bought it, no wonder it didnt run good. ![]()
#19 |
91 SWB 383
they r still for sale
