Old 05-15-2016, 09:59 PM   #1
trout
Old member old truck new update
Started out with a 87 r10 complete stock 305 700R4 transmission 273 gears in the rear half ton truck 2 wheel drive went over the years of spray painting a changing body panels lowered it changed out the motor twice change the transmission and six times changing out the rear end and then finally got tired of the two wheel drive and having problems with it and having frame problems with a cracking in the rear end up going out and it ended up pulling it all apart and having a buddy that had a 79 K20 that you was getting ready to sell so I bought it ripped the motor out of it with the body off of it and set my body on there but the only thing that's Factory to the 87 is cab n driver door everything is either 78-74 or NOS and then got a 12 in super lift from Summit Racing and got brake lines 2 & a half inch shackle flip kit to replace a 3-inch block that came with the kit and new bolts from ord and now I have what you see here
Edited by staff
trout is offline   Reply With Quote
Old 05-15-2016, 10:00 PM   #2
trout
Re: Old member old truck new update
And with its rollers on
Edited by staff
Old 05-18-2016, 09:42 PM   #3
trout
No comment wow ok
Edited by staff
Old 05-18-2016, 10:58 PM   #4
UKNOWME
UKNOWME's Avatar
Quite honestly it looked better before.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 05-23-2016, 10:31 PM   #5
trout
Pics make it look realy good had rust and dents
Edited by staff
Old 05-24-2016, 12:15 PM   #6
daddyjeep
daddyjeep's Avatar
It is certainly a different approach than where you were before. Where do you go from here? Do you plan on running the Hummer wheels and tires that are in the first pic?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-24-2016, 02:55 PM   #7
68Timber
I know the pieces fit
68Timber's Avatar
Did you sell the K5 you'd started on a while back? Wondered where you'd been.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
