Old 05-16-2016, 10:26 AM   #1
tow21
Ls swap question
I'm doing a ls swap.on my wife's 70 it a 2010 6.0 with a 4l90e trans. I was wondering what you guys that are doing them are using for radiator hoses? I bought a stock radiator but aluminum went through some of the threads here but nobody really says what they came off of. Also had to cut the trans tunnel does anyone know what year high hump trans tunnel will work? Any help would be great
tow21 is offline   Reply With Quote
Old 05-16-2016, 01:38 PM   #2
Matt Cramer
Re: Ls swap question
Not sure on the trans tunnel, but I used hoses for a '05 Silverado for an LS swap. I had to trim about an inch off each end of the lower hose.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 05-16-2016, 02:12 PM   #3
XwalkerX
may want to check out this section
http://67-72chevytrucks.com/vboard/f...play.php?f=206
XwalkerX is offline   Reply With Quote
Old 05-16-2016, 04:11 PM   #4
tow21
OK thank you I'll look into it
Old 05-16-2016, 04:12 PM   #5
tow21
Ok awesome thanks again I'll look into it
Old 05-16-2016, 09:37 PM   #6
Aruba1
Depends what radiator you use. I had the inlet/outlet at the passenger side as some has claimed to be better for the LS. I used the stock LS upper "or" lower hose and I was able to make it into the upper "and" lower radiator hose. I believe it was the upper that I used. If you go with stock LS radiator you can use stock hoses.
When you say you bought a stock radiator, are you referring to the 1970 or stock 2010 radiator? :-)
Aruba1 is offline   Reply With Quote
Old 05-17-2016, 08:44 AM   #7
tow21
Ya I ment for the 1970 stock radiator
Old 05-17-2016, 12:44 PM   #8
michael bustamante
michael bustamante's Avatar
im going to be using the stock style brass rad that i had in my truck already. inlets and out lets seem to be the same. the stock hoses look like they could be made to fit with a slight trim
its a 4 row as well. 1967 c10
1967custom
michael bustamante is offline   Reply With Quote
Old 05-17-2016, 01:05 PM   #9
MalibuSSwagon
With 1" setback plates (placing engine in same position as SBC) the Silverado hoses worked perfectly with the stock radiator. This was on an 86 C10 but I can't imagine yours being much different.
MalibuSSwagon is offline   Reply With Quote
Old 05-17-2016, 01:53 PM   #10
davepl
davepl's Avatar
Not the truck but this is just yesterday so I'm going to post it anyway since this is an LS swap thread!
Just got it mounted, connected to the trans, clutch, all of that. Clears the steering box and the firewall, just BARELY.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-17-2016, 09:13 PM   #11
SoCoC10
SoCoC10's Avatar
I used a vehicle specific LS radiator for my 65 Chevelle. The Griffin built radiator was $350 +\- through Summit racing. I too went with passenger in and out locations for the hoses and used a CSR straight thermostat housing that uses the small block Chevy t stat.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 05-18-2016, 03:12 PM   #12
Pillow
Pillow's Avatar
Check my build thread. Has the hose PNs for keeping the stock radiator.
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King!
'83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress
'92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress
'79 Porsche 911 SC
'48 Spartan Mansion 30' travel trailer
'10 Porsche Cayenne S - Daily
Pillow is offline   Reply With Quote
Old 05-18-2016, 03:16 PM   #13
zach_carver
zach_carver's Avatar
Youll also need a coupling to attach the steam port from heads into cooling system if your using the factory radiator.. You may already know this though.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
