05-16-2016, 11:30 AM | #1 |
Rebuilding Q-jet
I have been tearing apart my q-jet because of strong smell of gas when driving. Well when I took top plate of Q-jet off there was a broken pencil tip in the top of the vent tube??????? Some kind of Q-jet tuning I have never heard off LOL. I was also surprised to see threaded bolts(why would they be there, see pic) on either side of carb. Every time I open a q-jet I find interesting things that have been done to them. Anyway I think I inhaled to much carb cleaner fumes since I don't remember what is the base setting for idle mixture screws on a 4 barrel Q-jet. Do most people do 2 1/2 turns or 3 1/2 turns from bottomed out? On my 79 the idle screws were all the way closed down and with that pencil stuck in vent tube I am surprised the truck even ran down the road. My dad said this carb came from Advance auto and so that might explain why it was so beat up.
79 Chevy 2wd BIG10 350 TH400 |
05-16-2016, 12:16 PM | #2 |
Re: Rebuilding Q-jet
The one on the outside is for idle speed. It's really just an adjustable stopper for the throttle body
05-16-2016, 01:10 PM | #3 |
Yeah not the idle speed adjuster just below it you can see a darker round circle inside the carb body. That is the screw that was placed in the bowl right there, you can actually see some threads poking out of the hole.
05-16-2016, 01:15 PM | #4 |
Oh I see it now. That's weird. Maybe someones attempt to straighten out some warpage?
05-16-2016, 06:59 PM | #5 |
That hole that the screw is stuck in is part of the idle air bypass system used on some Q-jets.
Make sure you put that secondary vent tube back in the hole it fell out of.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. Last edited by ron350; 05-16-2016 at 07:05 PM. |
