Old 05-16-2016, 08:13 PM   #1
66 GWN
Transmission Fluid Level
Hey Everyone. Finally got to start the truck..
First time in 4 years. i've checked all fluids, manually turned it over to ge the oil throughout the block.... etc.. all ok.
Went to put it in gear and nothing. checked the fluid in the tranny (powerglide automatic) and it was low. Put some fluid in and it moves just fine. So now to my question...
When do you check the fluid level? when motor off, on, warm, cold, in neutral?
Any advice appreciated....
66GWN
66 GWN is offline   Reply With Quote
Old 05-16-2016, 08:41 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: Transmission Fluid Level
hot in park you should see that written right on the dip stick a lot of people don't look at the whole dip stick but it tells you on the stick what to do.
69chevytrucker is offline   Reply With Quote
Old 05-16-2016, 08:46 PM   #3
66 GWN
Thanks. But how do I get it hot if I can't drive it yet? Also should the level be higher when it sits over night and I check it or higher when hot and in park? Right now it is at full when parked and cold..
66gwn
Old 05-17-2016, 12:48 AM   #4
Captainfab
60-66 Nut
With the trans cold and the engine off, the trans fluid should be a bit above the full mark. But I can't say exactly how far. If you can't get the trans warmed up, I would leave the fuild level where it is until you can. You do not want to overfill the trans..
Old 05-17-2016, 09:40 AM   #5
jbgroby
jbgroby's Avatar
On my 1960 Hydramatic, it states on the dip stick, check fluid level while in idle. FYI, This might be a great idea for a new Thread. Posting all we know about the various transmission.
jbgroby is offline   Reply With Quote
