05-17-2016, 09:44 AM | #1 |
Motor mount issues
I'm putting a 6.0/4L80E into my 77 C10 2wd. I bought a set of the aluminum adapter plates off eBay that use the original clamshells. I've had a heck of a time with these things, they didn't come with instructions so I installed them backwards the 1st time. I have them installed the correct way now and have the clamshells bolted to them. The issue I'm having now is that I can only get one bolt hole to line up. Right now the drivers side is lined up and the bolt is in it but not tightened up. The passenger side still needs to come down and towards the center of the truck about 1/2" to 5/8".
I've fought with thing for about 4 hours now. Does anyone have any helpful advice? I'm considering throwing these plates in the trash and ordering Dirty Dingo's or Tejas. If it will help, I'll try to snap some pictures tonight and post them tomorrow.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
05-17-2016, 10:06 AM | #2 |
Re: Motor mount issues
Like this. The thickness of the aluminum is causing the issue. I ended up milling them down to 1/4 " thick. All is good now
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
05-17-2016, 10:10 AM | #3 | |
Question is Dirty Dingo sliders or Tejas?
05-17-2016, 10:30 AM | #4 |
65standard I assume that is after you had them milled down as that looks like a good fit.
I know there is some "slop" in all the parts including the rubber I am surprised they are not working. Just my thoughts.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-17-2016, 10:38 AM | #5 |
I'm pretty surprised too. I'm just at my wits end with them and want to be done with this part and move on.
05-17-2016, 10:43 AM | #6 |
Have you tried loosening up the motor mounts on the stands, and then getting the through bolt in? Then you could tighten them back down, or maybe slot the holes a little in the stands to give you some wiggle room.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-17-2016, 10:55 AM | #7 |
I haven't tried that, but I will. I guess my main concern is that I don't want to "force it" to fit if that makes any sense. I will give that a try tonight. Thanks.
05-17-2016, 11:04 AM | #8 |
I loosened the entire frame stand on one side, and then removed the top set of bolts on the other, and then was able to drop the motor down and line everything up. I used a screwdriver to line up the holes and get the bolts started. Worked great.
05-17-2016, 02:50 PM | #9 |
05-17-2016, 07:57 PM | #10 |
meowMEOWmeowMEOW
FWIW, I don't have the clamshell mounts on this one BUT; everytime I put mine in, I had to start one bolt on either side while the engine still had its weight on the cherrypicker. Then I'd use those bolts and a pry bar to guide the engine in as it was lowered, starting any other bolts wherever it lined up best along the way. Without doing that, mine wants to wander to one side and make getting the other bolts in very tough.
05-18-2016, 10:26 PM | #11 |
I feel your pain, I wrestled with mine for two evenings in a row to get my dirty dingo ones to line up. I wanted to burn the truck lol because I thought mounting it was gonna be the easy part! Boy was I wrong ha. I ended up having to slot my stand so it would allow bolts to start on both sides. Mine was the other style mounts though. Don't feel bad though your not the only one.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
