![]() Join Date: Jul 2001
7 Blade Clutch Fan F/S
Nice, bead blasted, primed and painted semi-gloss black. Will fit for BBC or SBC depending on your shroud diameter. GM PN# 3991431, believe is early to mid 70's. $25 plus shipping, money order or $$ only, do not have Paypal.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
![]() Join Date: Jul 2014
Re: 7 Blade Clutch Fan F/S
I will take it depending on the diameter. I need it for a 1972 SBC 4x4 truck.
Sorry, forgot to add that, 19'' tip to tip. LMK, thanks for the interest.
I will have to pass. I need a smaller fan for the 4x4 shroud.
All about them K’s
![]() Join Date: Jun 2014
How much shipped to 87455?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Looks to be $12.50 shipping using USPS, Priority Insured with 3 day service. Using the USPS on-line website for quote. 5 lb. weight, box 20x20x3. Total to your door $37.50, let me know and thanks for the interest. Zip code came up as Newcomb, NM.
All about them K’s
Newcomb is correct I use a PO box for USPS. Do you have any way to confirm it will bolt to a 67-72 fan clutch? If not could you post spacing dimensions for the bolt holes across from each other and the diameter of the center hole? I've got a spare clutch for a 72 that I'm going use in my 3100. I don't have a good fan for it.
It's always been my understanding that a GM clutch fan will mount to either a BBC or SBC clutch, no difference. This fan measures 2 1/4'' from bolt hole center to bolt hole center going from corner to corner. Measures 3 1/4'' hole center to hole center when measuring as in a diameter measurement ACROSS thru the large open hole. Hope that helps. Center hole of fan measures 2 5/8'' in diameter, forgot to include that.
I can confirm the BBC/SBC with my local parts store guru tomorrow. He KNOWS his parts, been in the parts business for nearly 35 plus years. ![]()
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 05-19-2016 at 10:49 PM. Reason: Added Diameter of Center Hole |
Spoke to my parts guy this afternoon and he confirmed; the fan WILL mount to either a SBC or a BBC water pump with no problem. Thanks for the interest, let me know.
All about them K’s
Ok I'll send a pm over
