Specific years that are compatible with 62
Are there specific years that are compatible when it comes to swapping front and rear ends? I would like to upgrade to 5 lug, coil suspension, and disc brakes. Thanks in advanced.
Posted via Mobile Device |
1961 crewcab
Re: Specific years that are compatible with 62
73-87 will work, markeb01 has a great thread on the swap I think in the faq section
rear would also work out of the same donor, but you would have to buy and weld on new trailing arm perches. capitanfab makes a nice set.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#4 | |
