05-18-2016, 09:40 AM | #1 |
Does a 2.5/4 drop need the exhaust tucked ?
Just wondering if I need to tuck my exhaust for my upcoming 2.5/4 drop ?
I'm getting ready to start my chassis rebuild (sandblasting etc. on my ground-up resto) and if I need to tuck my exhaust I of course want to do the main cross-member mod (4" holes and pipe install) before I blast, paint and reassemble... I want to keep this all-original truck as factory as possible, so I'm looking for some input/opinions (before I go cutting holes and making mods I don't really need). |
05-18-2016, 10:57 AM | #2 |
Re: Does a 2.5/4 drop need the exhaust tucked ?
Short answer is no, I have a 3/5 and my headers are a good two to three inches below the frame rail and I have never touched them. That being said if you want to go any further than 4/6 you will need to tuck the exhaust, I plan on doing that at some point (replace headers and new exhaust) as I will probably settle on a 5.5/7.5 static drop. But that will require lots of other parts, C notching the frame and so on, and I don't have time for that right now.
1972 C10 - It might be old, but it's not slow |
05-18-2016, 11:10 AM | #3 |
Good to know DBK, especially from a prairie-neighbor, I swear the same pot-holes and speed-bumps around here grow another couple inches every year.
05-18-2016, 12:21 PM | #4 | |
05-18-2016, 01:01 PM | #5 |
No problem, SK roads make AB roads look like the autoban!
I'm running Headman Long tube ceramic right now, and will go with the Headman mid length, painted headers when I do it, can't recall the part number, but I have it written down somewhere.
05-18-2016, 01:46 PM | #6 |
Does anyone run their pipes from the headers under the cab or bed? I have heard people call them turndowns. Just wondering if this would be easier? Too loud?
05-18-2016, 02:12 PM | #7 |
Divorced .....WITH KIDS
I had turn downs in front of my rear axle . Very loud and dusty . I could literally see dust being blown from under my truck and between the cab and bed .
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
05-18-2016, 02:32 PM | #8 |
I have turn downs on my truck but I also have the exhaust tucked so I don't get much dust. It is loud though so if you have the room I would go over the axel. I have a 5 inch drop in the back and I ran into clearance problems with the axel.
05-18-2016, 03:06 PM | #9 |
When I did my 3"/4" drop, I switched to Hedman midlength headers. I hated how far the long tubes hung down. I had to have the exhaust re-routed because the existing pipes hit the rear axle after the drop.
1969 Chevy CST/10 396, PS, PB, A/C |
05-18-2016, 03:09 PM | #10 |
The Hedman middies that I used were #69010.
05-18-2016, 03:20 PM | #11 |
05-18-2016, 05:25 PM | #12 |
