Rear Suspension 1970 K20 ?
So I need some help with my rear suspension on a 1970 K20 4X4. Does anyone know if it has a bump stop on the rear suspension. I was looking at the LMC catalog and it shows one for the 4wd models but I don't even have a bracket for one to be installed. Maybe the PO removed it or it just doesn't need one. Any one have an idea if its needed/used for this year. Thanks!
![]() Join Date: Apr 2013
Re: Rear Suspension 1970 K20 ?
The bump stops on a 4 wheel drive are bolted in above axle.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
Thanks for the info. Do you happen to have a picture of what it looks like?
This is on my K10 but I think the K20's are the same.
20' Daredevil (Ret)
![]() Join Date: May 2003
^^ That's the same as the bump stops on my '72 K20.
Thanks for the pic. That helps out a lot.
![]() Join Date: Apr 2007
Also the same setup as a 69 k20 yard truck we have here.
