Old 09-29-2003, 03:31 PM   #1
GreenMystChevy
what brake system for my 3/4 ton?
So if I am putting '75 3/4 ton 4x4 axles under my '72 GMC 4x4 and am needing power brakes, how would I go about doing this?
What master cylinder and power brake booster, what brakes lines are going to be different, etc.?
I am wanting to do this right but do it without killing the budget. Is there a year of truck that I can strip, what can or should I buy used, etc?
Thanks guys.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 09-30-2003, 11:56 AM   #2
GreenMystChevy
Someone knows this I'm sure. Hmm, maybe I didn't explain it well enough
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 09-30-2003, 12:11 PM   #3
Mudder
Mudder's Avatar
I'm running 3/4 tons on a 77 chassis. I once had disks front and drums rear but running all disks now. I am using the original booster and master from a 67 with drum brakes. Have never had a problem and it stops great. I do change the pads regularly and use the cheap ones. (They seem to work better)
Mudder is offline   Reply With Quote
Old 09-30-2003, 12:13 PM   #4
jose
jose's Avatar
I think all you have to do is replace the brake hoses running from the calipers to frame . 1/2 ton and 3/4 ton are different . Replace the power booster with 3/4 ton . 71/72 3/4 ton power booster set -up will bolt right up .
I am assuming your 4x4 is 1/2 ton ?
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 09-30-2003, 12:22 PM   #5
GreenMystChevy
Ok, so if I get a 3/4 ton brake booster and master cylinder from a '71 or '72 3/4 ton and then got 3/4 ton brake lines down by the axles for a '75 3/4 ton, that should do the trick?
Thanks guys for the input. Now to do some hunting.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
