Old 05-18-2016, 03:46 PM   #1
ChuckLee
Where can I find 73-87 mounts and clamshells?
As title states, anyone know where i can find 73-87 mounts and clamshells for an LS swap I'm doing in my 69 C10? I'll be running the corresponding DD sliders with these mounts.
I have a 69 C10 I'm going to do a 5.3/4l60 swap in and I'm starting to put together a parts list and order stuff. I haven't been able to source this particular part on the forum.
ChuckLee is offline   Reply With Quote
Old 05-19-2016, 05:17 AM   #2
LeesTruk
Re: Where can I find 73-87 mounts and clamshells?
I've got some "clamshells". Send me a pm
LeesTruk is offline   Reply With Quote
Old 05-19-2016, 09:27 AM   #3
Hart_Rod
Hart_Rod's Avatar
ECE sell both
Hart_Rod is offline   Reply With Quote
Old 05-19-2016, 09:46 AM   #4
ChuckLee
Originally Posted by Hart_Rod View Post
ECE sell both
Thanks for the help there. I didn't know that. I looked at their kit. I wonder if there is a kit that includes sliding Ls mounts.
Old 05-21-2016, 12:53 PM   #5
ChuckLee
Bumpity
Still on the lookout.....primarily for someone that sells just the actual frame mount/perches
For others looking that don't need/want adjustable sliding LS mounts, this kit does certainly fit the bill as mentioned above.
http://www.earlyclassic.com/home.aspx
Old 05-21-2016, 05:30 PM   #6
Vandals909
I had to go to a junk yard for mine. Paid around $50 I think.
I was told by Captain fab if your using them on a 67-72 c10 that the 73-88 c20 mounts work better as they are taller.
I havent had the change to drill and mount mine yet but they sit nice.
http://www.ebay.com/itm/1973-87-Chev...VXJf~f&vxp=mtr
Vandals909 is offline   Reply With Quote
Old 05-21-2016, 10:17 PM   #7
ChuckLee
Why would you want them taller?
Old 05-25-2016, 06:22 AM   #8
1978chev
I used the kit from ece motor fits great.
I bought a set of used perches turned out they were from a 4x4 did not
Work at all.
1978chev is offline   Reply With Quote
Old 05-25-2016, 08:31 AM   #9
ChuckLee
I have in my mind that if I buy the 73-87 perches and the Dirty Dingo sliding mounts that I will be able to use my stock driveshaft as was done on http://67-72chevytrucks.com/vboard/s...d.php?t=517347
Maybe that is wishful thinking? Not sure. MAybe I should just buy the ECE kit as well
Old 05-29-2016, 04:03 PM   #10
Vandals909
Sorry for the delayed response. Taller because they fit our 67-72 frames better.
PM from Captain Fab, who is super knowledgeable.
Originally Posted by Captainfab
Hello
If you want to use the better '73+ engine mounts, you will want the frame brackets from a '73-'86 C20,30 or a '87-'91 R2500/3500. Those brackets fit the '72 and earlier frames best. The C10 brackets are too tall and require a spacer on top of the frame.
The brackets from a 4wd are totally different and will not work.
John
Old 05-30-2016, 12:36 AM   #11
ChuckLee
Bought a set. Thanks guys. Now it is official, I'm buying swap parts! Let's get this show on the road.
