1976 vent window rivots
Anyone know when I can get new rivots. I want to replace my seals and rivot them back in.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
Re: 1976 vent window rivots
Look at your windows. I drilled mine out in the channel. Not the pivot point. Simply used steel rivets when I installed them
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
By steel, do I mean pop rivets?
Yes
To change your seals properly you will want to remove the pivoting glass frame from the vent assembly. You can use pop rivets for the division post seal, but the outer pivot is a stepped rivet that would require a mushrooming tool. There are rivet kits available thru several suppliers that have the seals and new glass.
I'm already done with the project. Thanks tho
Classic Parts have them and LMC has them too. Check out there site.
http://www.classicparts.com/ http://www.lmctruck.com/index.htm
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
