05-19-2016, 07:00 AM | #1 |
5.5 7 drop with 235/75/15
I've looked thru the drop posts but can't see any or missed them. I'm currently at a 3 5 drop. Can I do a 5.5 7 drop without any issues with my tire wheel set up? Exhaust or tie rod? Anyone have any photos and with white walls if possibile?
05-19-2016, 08:43 AM | #2 |
Re: 5.5 7 drop with 235/75/15
I wouldn't go more than 4.5" in the front. Crossmember gets REALLY close to the ground and the 3" springs cause issues with being able to get alignment in spec.
7" should be fine in the back with shock relocation. I have a leaf flip on the rear of my '69 that netted just over that amount using the DJM kit. My front is 4.5" with ECE disc spindles and 2" springs.
05-19-2016, 09:30 AM | #3 |
I'm looking at doing a 3 / 5 on my 72 long bed also . what did you use to do yours ? I'm also using 15 " tires. love the look of your truck.
05-19-2016, 09:48 AM | #4 | |
Picture is with the arm jacked up so it is close to the frame |
05-19-2016, 09:59 AM | #5 |
Anyone use these from AutoZone? They are like $32 for 2in blocks. They have up to 3in I believe.
05-19-2016, 12:08 PM | #6 |
Lowering blocks are lowering blocks, just make sure U bolts are of decent grade, and you really can't go wrong. $32 seems like a hell of a deal.
1972 C10 - It might be old, but it's not slow |
05-19-2016, 02:42 PM | #7 |
7 inch in back , you need a c-noch in the frame
5 in front , im sure 2 will have to come from lowering spindles , tire size and maybe other front end issues will come into play , lots of experiance on this board , someone who has done it will chime in , mine 3 5 , no issues , Ive herd of others doing 4 6 with no issues , but 5 7 , I know you need a c-notch minimum
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
05-19-2016, 03:43 PM | #8 | |
67-72 parts collector,…
Those are leaf spring lowering blocks. You need trailing arm lowering blocks. http://67-72chevytrucks.com/vboard/s...d.php?t=454824
05-19-2016, 03:49 PM | #9 | |
How do you tell the difference? |
05-19-2016, 04:13 PM | #10 |
Look at the pictures!
The leaf spring style has 4 unbolts and no holes. The trailing arm style has 2 much larger u-bolts and holes in the blocks that match the hole spacing on your truck rearend and shock plates. You won't find these at your local auto parts store. These are specific to 60-72 trailing arm trucks.
05-19-2016, 04:18 PM | #11 |
Here is a 5/7 static drop my dad did. Running 20 inch wheels and no frame modifications or clearance issues
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
05-19-2016, 04:54 PM | #12 | |
