![]() Join Date: Feb 2016
66 C10 Rim Selections
building my C10 with 2.5 drop spindles, stock BBC front coils and 4" drop rear coils? any thoughts or experience on the rim/tire size that would compliment this setup? i was thinking going with standard 15x7 rally rims (5 lug) similar to what was used on the Chevelles and Camaros.
Re: 66 C10 Rim Selections
Those rally wheels look awesome.. my buddy just put them on his truck. I am now figuring out though that those factory 15" rally wheels don't accept disc brakes. So if you have disc brakes or are planning on doing them down the road you might do more research. I am currently facing this dilemma. I've got 255/70/15 on mine and I think they look much better then the next size down.. especially in the front. If you dont fill up that big front fender well it looks kinda goofy. I made that mistake on my 62'. Here's my 66" with the 255/70/15 setup.
Yes on discs
Suggestions? |
I actually just started a thread on this same topic. I'm looking at disc brake conversions myself right now. All of the kits though say that they may not fit with factory 15" wheels. So I'm trying to figure out if that means just the factory Wheels or most 15" wheels.
Some rims don't have enough clearance for the caliber. So a older drum rim has the potential not to clear.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
![]() Join Date: Oct 2006
I used some 15X8 5 lug rallys that I got for free on my disc swap
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
So 15x7 or 15x8 rallys will work?
I converted to 5 lug as well. If so best tire match for this setup? |
Going with 15x8 rallys i think
Thoughts on which backspacing is best?? Again i swapped to the disc brake conversion with the 2.5 drop spindles |
![]() Join Date: Nov 2012
Here are my Chrome 16" wheels with wildwood disc brakes with 255/70/16 tires
i like those. who made the rims?
This came from Custom Wheel Outlet on their 15x8 rallys.....Sorry, the hub bore on this wheel is not large enough to fit over your hub. You need a 108mm clearance or larger, and that wheel has a hub bore of 81.7mm. ah...this is greek to me. |
These wheels are from Summitt $90.00 ea. They are made by US Wheel. The center caps are Crager, bought those from Summitt also, $10.00 ea.
#13 |
Here is a better view from the side
#14 |
If you are going with a 15" rim don't get the modular drop spindles from CPP they will not work. Just a warning.
#15 |
![]() Join Date: Aug 2014
15" Wheels and disc brake all depend on the wheels. I have disc brake on my 65 with 15s and they fit perfect. If your changing to 5 lug nearly any wheel will work. Factory 6 lug steel wheels wont accept disc brakes due to the dish on inside of wheel. All depends on how many nubs there are on the face of the wheel. As far as I know most all 5 lug wheels will work with disc because most 5 lug trucks came factory with disc brakes. Any of your later model truck rallys and all should work with disc brakes.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#16 |
#17 |
i have the Western Chassis 2.5 drop spindles if that helps.
