Wiring for Alternator
Anyone have a simple wiring diagram that shows how to wire an alternator as a replacement for a generator? Including what to do with wires for existing voltage regulator.
Probably going to install a single wire alternator for first couple weeks as I have materials in the shop to do so. Working on a 1958 Apache. |
Re: Wiring for Alternator
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
I think this is the one you want.
![]() I've used this one a few times and while it doesn't show running though the original wires it is real simple ![]()
Here, this is on a tri 5 car but the process is the same and they walk you through it step by step. http://www.dreamcarenterprises.com/c...Conversion.pdf
#6 | |
