Old 05-19-2016, 02:48 PM   #1
steveo3318
steveo3318's Avatar
Is there a Wilwood D52 complete kit for front and rear???? Please help
I have searched until I am blue in the face and can't find what I want in a kit. My 67 has 72 suspension and brakes so let's start there.
All I want is the red Wilwood front 2 piston brakes with a slotted rotor and I want a d52 drum to disc conversion out back in red. Does anyone make this as a whole kit?
My truck is disc up front drum in back with the correct master and proportioning valves for that in stock form.
I am not wanting to go big brake. Only disc in back and drilled slotted red calipers for looks. Thanks guys.
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 08-26-2017, 09:16 PM   #2
PaPaStewySnipes
Re: Is there a Wilwood D52 complete kit for front and rear???? Please help
I'm wanting the same exact thing, kit for font with rotors and calipers, braided lines... with d154 full rear brake kit. I'm driving a 1971 hmm c15. I just need rotors, seals, bearings, and calipers for font. I see there is some kits for the d154 rear brake.
PaPaStewySnipes is offline   Reply With Quote
Old 08-26-2017, 09:37 PM   #3
harpo231
harpo231's Avatar
http://www.wilwood.com/BrakeKits/Bra...ke+Spindle+(OE)
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 08-27-2017, 10:35 PM   #4
Z10
Z10's Avatar
I have a 72 and purchased a Wilwood kid from http://www.azproperformance.com/Brakes/
which is contributor to this site. They'll have exactly what you want.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 08-31-2017, 12:12 PM   #5
beaterku
beaterku's Avatar
Do you have any pictures of how the stock brake hard line connects to the Wilwood braided line and caliper?
beaterku is offline   Reply With Quote
Old 08-31-2017, 12:21 PM   #6
Z10
Z10's Avatar
I'm not sure if this is what you are looking for?
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 08-31-2017, 12:22 PM   #7
beaterku
beaterku's Avatar
Thanks!
Trying to get a handle on how the interface between the stock brake hard line and Wilwood braided line works. It looks like you welded a tab on the axle. Is this a Wilwood flex line?
Old 08-31-2017, 12:25 PM   #8
PaPaStewySnipes
My rear kit comes in on the 5th, I bought the same got it with rear drilled and slotted 690.00 shipped to my door, really good deal. I was wondering the same thing... How do I connect to stock rear lines. I did not order rear line because I was unsure and waiting till I get my hands on it. Any info on this? I called wilwood they said something about cutting back stock line 2" make a flair and connect to caliper using rear line kit. Not 100% sure my self.
Old 08-31-2017, 12:31 PM   #9
PaPaStewySnipes
Now in in the process of picking out what I need to support my disk disk setup. This is what I'm working with now, called pol for replacement master and correct proportioning valve. I'm looking into their 4" drop rear leaf as well. I'm about to order a direct replacement for my master and prop.
Old 08-31-2017, 12:47 PM   #10
Z10
Z10's Avatar
Here's mine.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 08-31-2017, 12:50 PM   #11
PaPaStewySnipes
Might just get that, I have been looking at that exact set up will cost me $100 more but it is so shinny :-). Will it fit to my factory booster? And what adapters do I need to make it fit.
Old 08-31-2017, 12:54 PM   #12
PaPaStewySnipes
On my factory I have one line out for front and one out for rear. I'm sure they both go to a T. Havent had a chance to crawl under and get a good look
Old 08-31-2017, 01:02 PM   #13
Z10
Z10's Avatar
That is a factory style booster, bolts right up. I had a lot of trouble with boosters and master cylinders and finally got a USA made one from Tuffstuff.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 08-31-2017, 01:05 PM   #14
PaPaStewySnipes
Yea, I'm trying to save my self some trouble, your booster looks exactly as mine, only better looking with the wilwood. I checked out the master and prop out. Very nice kit. Would it hook up to my stock lines, I have one out for front and rear currently. You ran some nice new lines and will be doing as you later on.
Old 08-31-2017, 01:12 PM   #15
Z10
Z10's Avatar
I had a friend of my, who is a fabricator do most of mine. I think all of my lines are new so we didn't use any of the old stuff. He's a big fan of CopperNickel brake line. It's easy to bend and won't rust just like stainless and less expensive.
You can see a lot of his work on my build link in my signature.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 08-31-2017, 01:23 PM   #16
AussieinNC
Moderator
AussieinNC's Avatar
Unhappy Re: Is there a Wilwood D52 complete kit for front and rear???? Please help
Sadly, on the link in your signature, none of your pics are viewable due to new photobucket restrictions...
Hope you have copies of those pics...
AussieinNC is offline   Reply With Quote
Old 08-31-2017, 02:14 PM   #17
PaPaStewySnipes
Part numer for your ww master and prop set is 261-13270-bk?
Old 08-31-2017, 02:25 PM   #18
PaPaStewySnipes
I can get summit to price match it for me at $275 free ship.
Old 08-31-2017, 02:28 PM   #19
beaterku
beaterku's Avatar
That's a pretty good deal. Who are they matching?
Old 08-31-2017, 02:37 PM   #20
PaPaStewySnipes
@z10 I was looking at your build thread and your front rotors match rear nearly perfect who makes those.
Old 08-31-2017, 02:38 PM   #21
PaPaStewySnipes
He'll of a deal. Sport compact warehouse. I hot them to match for my front ww d52 calipers $300 loaded and shipped.
Old 08-31-2017, 02:43 PM   #22
PaPaStewySnipes
Auto anything had 15% sale on all belltech I got the 3" drop spindle, springs and street performance shocks for whole truck shipped 590.00. Been shopping around. I even got the rear we d154 ebrake 685.00 shipped $104 off from autopartswarehouse drop shipped from WW, that is same rear kit as above.
Old 08-31-2017, 02:44 PM   #23
PaPaStewySnipes
Autoanything have belltech drop spindles on sale $265 cant beat the price and free shipping.
Old 08-31-2017, 02:45 PM   #24
beaterku
beaterku's Avatar
Nice! What bore size master did you go with?
Old 08-31-2017, 02:47 PM   #25
PaPaStewySnipes
Well the 261-13270-bk is 1.12 or 1 1/8". I'm checking to see if that is exactly what I need and will hit up summit.
