![]() Join Date: Jan 2002
wiring kit ???
just bought a "american auto wire" kit- anybody done one ? any hints or installation pointers ? there is an lnstallation manual w/ it BUT THOUGHT ID ASK ? THANKS
![]() Join Date: Nov 2012
Re: wiring kit ???
I installed one on my 66 truck. Very nice complete kit, but you will need a special crimp tool for the connectors. I was lucky a good friend of mine had one I could borrow. The instruction are very good with lots of options for different gauges, alternators and steering column conections. Good luck and have fun installing your kit.
![]() Join Date: Jan 2011
Re: wiring kit ???
Lay it all out on the bench and organize it by the instructions. Follow the steps they show and it will go just fine. Order a couple of rolls of the harness tape (no glue) and look up online how to tie the ends. I used regular electrical tape to hold stuff together before wrapping it. Makes the harness look factory. You can rent or buy the crimpers from them. I got mine off ebay.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: wiring kit ???
Here are the crimpers I bought.
![]() They have worked very well. Only thing I was not able to crimp was the #8 wire going to the alternator. Had to crimp that one with pliers and then I soldered the connector on. Great kit with lots of extras. Including a new ignition switch and several grommets. I bought the 6 pc firewall grommet set from Car and truck shop. I have several pictures on my build thread where I started the install process. Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
Re: wiring kit ???
I installed the same kit and can't stress enough the need for that Delphi crimp tool. Don't bother trying to go around it.
Crimp pliers ??? Any for sale used ??
i went to the site -checked out the crimp pliers ! do i need both of the pliers ?? the wey i understand it /i will if i do the headlamp and the alternator ?? ANYBODY GOT A USED SET FOR SALE ???? PM ME IF YOU GOT ANY !! thanks
