64 k10 to c10 conversion
can it be done
Re: 64 k10 to c10 conversion
anything can be done. but why screw up a 4 x 4 when they are not that easy to come by as 2 wheel drives are. be much easier to find someone who is looking for a 4 wheel and trade or sell it and buy a 2 wheel that you are happy with and save yourself the work.
ron |
Yep what he said^^^^^^^
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
and a few others
Yup,
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
ya thats kinda what ive been thinking lately my next question is , would it be worth doing the reto work and then selling or just sell now and find 2wd
resto
and a few others
Lots of guys here who may be interested in it as-is.
Sign up for a subscription here and you can advertise it in the "trucks for sale" section of this forum. Further information on the subscription levels available are located here
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
If it's an all original truck, simply leave it alone and sell it off to someone who's interested. An all original is much better judged as is.
Restoring it can be expensive and might not be a great return on your investment.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
So im thinking im going to keep it and do a upgrade and make it a nice driver for the summers and im open to all suggestions on where to start
how long has it sat? probably has a family of mice in it.
tow it out of the field, see if the engine turns over, drain fuel and inspect tank (replace if needed), new tires, inspect brakes, change oil and filter, new plugs (squirt a little marvels mystery oil in each hole), new wires, new distributor (rent an oil pump tool from autozone and prime oil), carb might need a rebuild, fresh battery and see what happens. Not cheap or easy just to safely get it back on the road. Nice truck though and someone will buy it "as is" but would pay more if it's running. Is that engine original? Looks like my 327 in my 68 K-10. BTW nice backdrop you have there... big sky country for sure!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
the reason i posted the pic of the engine is im not sure if it is original from what ive seen 327 didnt come in a k10 until 66? im the second owner iit was driven to that spot in 1994
#13 |
on the passenger side of the engine, there is a flat pad in front of the valve cover. Clean that off and look for numbers...
#14 |
what do the six lug wheels mean? i thought !/2 tons all had 5lugs ?
#15 |
im currently bobbing around in the pacific ocean and my internet is scetchy at best but ive been looking at a lot of pictures trying to get ideas wont be able to drag it out of the field til july and there are no mice families but the yellowjackets love it in the cab
#16 |
that is the mission valley in nw mt
#17 | |
post in the 4WD section and you might get more specifics.
#18 |
#19 |
60-66 1/2 tons all came 6 lug on a 5.5" bolt circle. 2WD and 4WD were the same pattern. The wheels were interchangeable.
One of the nice things about GM a lot of parts are interchangeable. When your able you can post the engine suffix code and we'll be able to tell you your engines application. After a cleanup that truck will look amazing.
#20 |
there are several little dings and dents but nothing is crushed so im hopeful that the body work portion wont be too bad. im thinking of disc brakes all around and just beefing up the 327 but nothing crazy . obviously im in no hurry but i am going to drag it in to the shop in july and once it is there ill start peccking away at it
#21 |
without getting to crazy what can i expect to spend over the next 5 years or so?
#22 | |
But honestly, if you start taking it apart, the price will skyrocket... set realistic goals and get it safely driving first. Then do small fixes as you get to learn the truck. Check out my stalled build and you'll see what I mean, started it 9 years ago.
#23 |
also how would you know if it had the nabco 4x4
#24 |
ya i was looking at your build a while ago looks good so far. i understand what your saying i was just trying to get a rough idea of how soon i will be getting a divorce
#25 |
napco
