Old 05-20-2016, 10:24 AM   #1
1981_c10
1981_c10's Avatar
5 Lug Disk Brake Conversion
Hey Y'all,
Just purchased a 1962 C10 that has a five lug axle already swapped but has stock front 6 lug drums. With the purchase came 73-87 c10 brake booster and disk brakes. I have never done a conversion like this and looking for any tips and tricks before I begin. The frame is a true 62 frame with no coil springs. I figured that didn't matter much?
Thanks!
Builds:
1962 C10 Recreating Dad's High School Truck
1981 C10
1981_c10 is offline   Reply With Quote
Old 05-20-2016, 10:51 AM   #2
62stepside longbox
62stepside longbox's Avatar
Re: 5 Lug Disk Brake Conversion
Markeb01 has a very nice write up on the entire install with a 60-62 frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=366828
You should find all the info you need
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 05-20-2016, 11:22 AM   #3
slepysal
slepysal's Avatar
You can also use a spindle conversion that's what I did on my 60 fairly easy
http://67-72chevytrucks.com/vboard/s...d.php?t=682985
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-20-2016, 11:23 AM   #4
1981_c10
1981_c10's Avatar
Originally Posted by slepysal View Post
you can also use a spindle conversion that's what I did on my 60 fairly easy
I have a set lowering spindles I was going to try and use with it. Did you stick with the torshin bars?
Builds:
1981 C10
Old 05-20-2016, 12:26 PM   #5
slepysal
slepysal's Avatar
Yes , I just used the drop spindles and kept the torsion bar set up. I did have to tighten them up after to make up for the 2.5" drop that the spindles have.
Old 05-20-2016, 04:28 PM   #6
Big E's 62
Why would you use the drop spindles when you can loosen the torsion bars to lower the 62 you will have to to to alot of trouble changing the spindles.
Big E's 62 is offline   Reply With Quote
Old 05-20-2016, 04:40 PM   #7
slepysal
slepysal's Avatar
Because I converted to disc brakes, and used drop spindles to swap in the new disc brakes. I had my torsion bars loose but when I installed the drop spindles I had to tighten them up because it was to low.
Old 05-20-2016, 04:45 PM   #8
forestb
forestb's Avatar
Things start getting wonkie if you lower it to much with torsion bars and you run the risk of the bolts on the torsion bard scrapping against the ground.
forestb is offline   Reply With Quote
