Old 05-20-2016, 03:07 PM   #1
aotte1
16x6 6 Lug GM Steel Wheel with 4" BS
Did GM make 16x6 6 lug steel wheels with 4 inch back spacing?
Les
aotte1 is offline   Reply With Quote
Old 05-25-2016, 12:15 AM   #2
argonaut
argonaut's Avatar
Re: 16x6 6 Lug GM Steel Wheel with 4" BS
I have a couple of these stored somewhere. If I find them and I remember then I'll measure. But I would guess that they have something around a 3.5" to 4" backspace. Most of these wheels had close to zero offset.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 05-25-2016, 12:32 PM   #3
61K10
61K10's Avatar
Les--I've never seen one with 4" back spacing, just around 3.5 as Jason said. Not saying they aren't out there. Now maybe some were built for late model tks though?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-25-2016, 12:53 PM   #4
argonaut
argonaut's Avatar
I like these 16x6 because they fit nicely over disk brake calipers. They are pretty hard to find in my experience. I once had a nice matching set of 5 that came off one of my uncle's trucks, but since I transitioned both my 4x4 trucks to 3/4 ton I didn't need them and sold them. I would like to eventually locate a couple more to complete a set with the ones I still have and put them on my mom's 1/2 ton 64 pickup.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-26-2016, 11:54 AM   #5
61K10
61K10's Avatar
My 16x6 have 0 off-set they are trailer rims and Dot. they are built like the smoothy rims, no slots in the center hub. Black power coated at $65.95 eh. free shipping over $99. You do need different lug nuts. (as seen in my build)
1961 chevy K10
Old 05-26-2016, 12:04 PM   #6
aotte1
Jason,
What year truck has these wheels?
16x6 with 4 inch back Spacing.
Kimble,
thanks for the information.
Thanks,
Les
Old 05-26-2016, 10:15 PM   #7
RANDY COX
RANDY COX's Avatar
Les I'm running 16's from my ole 48 fleetline there 16's by prolly 3 1/2 to 4" wide there pretty narrow,I had to grind alittle on inside of wheel and also on caliper to clear..
without cap
these also have the clips for caps..
If I get a chance tomorrow I'll take a picture and measure the backspace..
here's a front view
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-26-2016, 11:16 PM   #8
aotte1
Randy,
Thanks for the photos, looks nice, BS would be nice if you get a chance.
Jason,
Research has pulled out a couple of applications for the 16x6, with 6 lugs:
O Blazers had them as an option, Jimmy maybe, from SPID photos
O Reseaching for more.......
If you find them, actual BS would be great, photo of the front too.
Thanks,
Les
Old 05-27-2016, 01:55 PM   #9
RANDY COX
RANDY COX's Avatar
Ok here you go looks like 4" backspace if I did it correctly..
Hope this halps you out...
1964 BBC 402 4x4
Old 05-27-2016, 04:29 PM   #10
argonaut
argonaut's Avatar
To me it looks more like 3" to the bottom of the tape...
But also the tape doesn't look to be sitting squarely on the other side of the rim lip.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 05-27-2016, 07:27 PM   #11
RANDY COX
RANDY COX's Avatar
yep 3" Jason I was looking at the top for some reason but if it were 4" then I wouldn't have had to grind some on the inside of wheel and caliper....My Dad had gave me a wheel one time to try on my ole car but it wouldn't work I think the center was either not big enough or something but it was a wide wheel but seemed like it had the clips for the caps..I'll have to look in my building to see if I still have it and I'll take some pictures, And I think he said he had 3 others so it would be a whole set...
1964 BBC 402 4x4
Old 05-27-2016, 08:09 PM   #12
RANDY COX
RANDY COX's Avatar
well I found it turns out it's 15"x6 wide with about 3" backspace...
1964 BBC 402 4x4
Old 05-28-2016, 11:31 AM   #13
RANDY COX
RANDY COX's Avatar
Looks more like 2 3/4 I think I need to learn how to read a tape measure again....
1964 BBC 402 4x4
Old 05-28-2016, 11:49 PM   #14
aotte1
Randy,
Thanks for adding the information on the 15" wheel too.
Les
Old 05-28-2016, 11:59 PM   #15
aotte1
Research, like that of many others here, is not showing, GM made 16x6 6 lug wheels, or at least they were not common. It is interesting why they continued to make the 16x5 6 lugs for so long.
Jason,
Will be interested in your 16s if you get a chance.
Les
