Where would I find this gasket? *Offset air cleaner.
Re: Where would I find this gasket? *Offset air cleaner.
buy gasket material at autoparts store and then you take sissors and after carfully laying it out cut it out is the oldschool way
![]() Join Date: Jun 2005
I just bought a taller filter element that sealed between the top and bottom housing. You could go to the home improvement store of your choice and pick up a roll of the correct width foam insulation with the sticky back and cut it to length. I don't know if you will find any companies that are reproducing that seal.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
you can buy rtv sealant in tubes or in bigger tubes for a caulking gun. clean out the groove and inject a nice even bead in the grove and wait for it to dry then install the lid
