Old 05-20-2016, 11:15 PM   #1
Steven R
Parts sourcing question
I have a 1971 GMC 3/4 ton LONGHORN 2WD
I cant seem to find a place that sells the U bolts to fit my truck, It has the aux overload leaf and spacer blocks in it from factory. Do you know of a place that sells them, and have you seen them or installed a pair from your source?
every thing i find only asks for 4 or 5 leaf but nothing with an aux overload leaf added like the pics. Or what should I be looking for or be calling what I have.
Hoping to match factory as close as possible. My plans are to have it sand blasted and painted but before I cut the bolts I want to order new ones. I have been trying for a while now and they won't move.
Steven R is offline   Reply With Quote
Old 05-21-2016, 10:35 AM   #2
Steven R
Re: Parts sourcing question
I found these at rockauto and i am going to give it a try and leave an update when I know how they fit/ work out
Prices as of may 2016
Part Price Quantity Total
1971 GMC C25/C2500 PICKUP 5.7L 350cid V8
Suspension : Leaf Spring Bolt
BHUSKY SPRING UA211S Shackle Bolt Info
Rear; 2-1/2" Wide Rear Spring; w/ Factory Contact Overload Springs; 5/8" X 2-9/16" X 10-1/2" Square Bend; w/ Deep Nuts & Thick Hardened Washers; 133.0" wheelbase
CAD$12.36
Suspension : Leaf Spring Bushing
BDAYTON RB117 Spring Eye Bushing; Outside Diameter 1.5" Info
FitsRear Rear; 133.0" wheelbase; w/ 2-1/2" Wide Springs
OrRear Front; 133.0" wheelbase; w/ 2-1/2" Wide Springs
CAD$12.06
Brake/Wheel Hub : Hydraulic Hose
ADORMAN H71305 {Click Info Button for Alternate/OEM Part Numbers} Info
Rear; 19.25 In. Length; One Male End and One Female End; Rear Leaf Springs; 133.0 Inch Wheelbase
Previous Image
Next Image
CAD$10.00
Old 05-21-2016, 11:08 AM   #3
old Chevy guy
old Chevy guy's Avatar
I had mine made at a local spring shop. However this may not be an option where you are. When I say local I mean 20+ miles not around the corner.
old Chevy guy is offline   Reply With Quote
Old 05-21-2016, 12:48 PM   #4
mike16
special order from NAPA? Also a local area Tucson spring vendor can special order them. Not rare reslly, they just dont move off the shelf fast enough to stock.
mike16 is offline   Reply With Quote
Old 05-21-2016, 02:06 PM   #5
davepl
davepl's Avatar
It's of zero help to you, but mine were so well preserved I was able to remove the U-bolt nuts by hand, without an impact, and just wire-brush and powdercoat them!
Normally I'm cutting them off with a torch, but this one truck was just totally rust-free.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-21-2016, 04:43 PM   #6
Gmc.guy
Gmc.guy's Avatar
Here you go into Napa and give measurement and they print a sheet that has a drawing of a u bolt. You fill it out with them It has axle tube diameter, total length and thread length and bolt size. They make you pre pay then go in the back and 15 minutes later they hand them to you. Last summer I had some stock replacements made for a trailing arm rear 12$ each in grade 8
-Cody
Gmc.guy is offline   Reply With Quote
Old 05-21-2016, 07:39 PM   #7
Steven R
Thanks guys, I appreciate all the good tips. I really just did nit know you could have the custom made so easy.
