05-21-2016, 01:03 AM | #1 |
meowMEOWmeowMEOW
Easy cutting for Aluminum plate/sheet
Anyone have tips on cutting larger pieces of aluminum sheet/plate around 1/8" thick?
I'm making a new race bedfloor, but I don't have a break or larger scale tooling like that. I'm talking a few pieces in the 2x4 foot range, and I need straight edges! Right now my best option is getting a few packs of dedicated aluminum cutting and grinding discs (really should have these in stock for fab work anyway), and just marking and cutting it like normal. I'd really prefer to get a flat, straight line however, and not deal with the possible scalloping and finishing marks from grinding a long edge like that. Thoughts? What about using a saber saw or sawzall and a jig for it to ride on?
05-21-2016, 07:56 AM | #2 |
Re: Easy cutting for Aluminum plate/sheet
You can cut aluminum with circular/table/miter saw with a carbide blade. Go slow and watch out for the hot chips.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
05-21-2016, 09:14 AM | #3 | |
Also spray a little WD-40 or similar on the blade every few inches of cutting to prevent the aluminum from building up on the blade....I usually have a helper to do that while I hang on to the saw. I've cut 1" thick aluminum plate with my circular saw.......thin plate is easy to cut......wear ear protection.....it will be LOUD!
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
05-21-2016, 09:36 AM | #4 |
I used to use clamps and a piece of angle iron for my straight edge for me to use the jigsaw to cut long cuts up to 6' long was the max for me it worked well with the right blades
05-21-2016, 03:37 PM | #5 | |
you can watch all you want for hot chips; as they stick to any exposed skin
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-21-2016, 06:43 PM | #6 |
I have one of my bandsaws set up with a fence just for items like this.
05-21-2016, 08:14 PM | #7 |
A carbide circular saw blade lubricated with beeswax works well with aluminum. As others have said, hearing protection is a must. So are long sleeves and gloves.
05-21-2016, 09:04 PM | #8 |
Too bad you're not closer...........
I have a neat old shear.....4ft x 10ga Niagara...
05-22-2016, 11:53 AM | #9 |
Use a plasma cutter with a piece of baseboard trim as a guide. Quick, clean edges and easy.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
05-22-2016, 12:28 PM | #10 |
05-22-2016, 08:14 PM | #11 |
meowMEOWmeowMEOW
Those are some good idea's guys!
05-26-2016, 02:34 PM | #12 |
It's Better With Nitro
I typically use a bandsaw to make cuts on aluminum thicker than my tin snips will handle. The abrasive cutters can generate enough heat to warp 0.125 aluminum.
