Aftermarket A/C-heater ? Help ASAP
I'm getting ready to install the heater hoses and not sure where to install the electronic heater valve. System is classic auto air and the motor is an Ls1. Water pump has 3/4 and 5/8 connections. The evaporator connections are both 5/8. Does it matter what hose I connect the valve to on the evaporator? The directions are a little vague. I'm assuming the 5/8 connection on the water pump would go to the heater valve. just not sure if it matters what connection I hook the valve to on the evaporator.
Re: Aftermarket A/C-heater ? Help ASAP
You have it right on the heater part. The hose from the receiver/drier goes to the expantion valve & then goes into the evap. It generally is a smaller fitting. The other end of the evap. goes to the comp.
The receiver/drier is part of the A/C And not the heater right. Does it not matter what heater hose I use going into the unit? They are not marked supply or return.
Old member
Doesn't matter what line you install it in. All you want is the water flow to be turned off to the heater when the switch activates.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
