Old 09-29-2003, 07:09 PM   #1
imdarren
imdarren's Avatar
Need opinions please . . . .
I have a Very Clean 72 GMC I will be sacrificing (donor truck) to get the 72 K20 Cheyenne Super looking beatuiful.
I will be taking the flawless bed and doors off of the GMC to put on the Super.
The querstion is . . . .
Before I sell the GMC (after the parts are swapped) should I take out the original 350 CID (needs rebuilt) motor to save for the Super. The Super does not have the original motor. It has a 350 out of a 74.
Would It be worth the hassle?
Would the Cheyenne Super be worth more with a #'s matching 350?
I know with crate motors being priced so well compared to rebuilding a motor, would it be worth the hassle?
I am planning on trying to get the truck back to stock / original condition.
Thanks for the advice.
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 09-29-2003, 07:56 PM   #2
jef5150
Inline 69
jef5150's Avatar
[quote]Would the Cheyenne Super be worth more with a #'s matching 350?.........more ?,,,,,probably not,unless you were gonna restore it to factory specs,,,,,,,imo
jef5150 is offline   Reply With Quote
Old 09-29-2003, 10:02 PM   #3
miket
miket's Avatar
For what it's worth....I kept my original motor (and all the original accessories pulley's radiator, shroud etc..) just in case...and I am really down on crate motors right now so.....not sure which direction to point you in.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 09-29-2003, 10:23 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
I like having the original motor in the truck, but it isn't that important IMO. My truck had the original motor in it when i bought it....but now it has a different 350. It would be a decent selling point, but i dont think i would pay any extra unless it was a loaded SWB Cheyenne Super with every option imaginable....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-29-2003, 11:55 PM   #5
Hooter
My other Love
Hooter's Avatar
that 350 out of the GMC is worth saving, older 4 bolt main, high nickle count blocks make kick ass high performance build-ups. is the numbers on it 3970010?. I'd keep the motor, old 4 bolt mains are getting harder to find nowadays, plus that motor will probably have a good set of 194 heads on it too
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-30-2003, 03:42 AM   #6
sameyrasmea72
sameyrasmea72's Avatar
If you plan on rebuilding one of the two, I personally would do the 72. However, If the 74 is a good strong running motor, I would say stick with it cost wise. It shouldn't make any difference unless you are going for an 100 pt. correct truck, then I would for sure use the 72.
I had the same delima as you on my 72 Cheyenne Super project. I HAD TO use a different engine and needed it to be as correct as posible. I found a 72 Sierra Grande, and used the 402 out of it, to keep the date codes close.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
