Old 05-22-2016, 01:38 AM   #1
ANTSOCL
Question Intellitronix guage
hey, i just bought this set up. i have a conversion to a 94 drive train. anyone know what wire from the ecm i hook up to the speedo. i read the vss wire i tried the brown and drk blue wire in the blue side connector. the blue didnt register any speed and the brown said i was doing over 160mph when i was barely crawling. i tried the original light blue wire with black stripe from the 94 instrument cluster plug it did not work either.
thanks in advance
ANTSOCL is offline   Reply With Quote
Old 05-22-2016, 11:08 AM   #2
12secondnova
12secondnova's Avatar
Re: Intellitronix guage
thanks in advance
I always thought the vss wire came straight from the transmission? I'm interested in this thread cause I plan on installing those gauges in my truck too...
12secondnova is offline   Reply With Quote
Old 05-22-2016, 10:10 PM   #3
ANTSOCL
do you have a 4l60e transmission as well?
Old 05-23-2016, 01:19 AM   #4
12secondnova
I have a 4l80e but Im not up to the point of putting it in yet still collecting parts. Just interested in finding out the answer to your question too in case I run into the same problem.
Old 05-23-2016, 01:54 AM   #5
ANTSOCL
well i have also tried to tap into the green and the purple wires that go to the drac, i beleive it is called, i think they come straight from the transmision and no luck there either
