05-22-2016, 02:58 AM | #1 |
Bench seat from an '81 C10 fits our trucks?
Does anyone know if the OEM bench seat from an '81 C10 is a drop in fit for a '65 C10?
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
05-22-2016, 10:55 AM | #2 |
Re: Bench seat from an '81 C10 fits our trucks?
05-22-2016, 11:02 AM | #3 |
The front bolts used the factory holes & had to drill new holes for the rear. It's a perfect fit I think my seat is from a 90's truck
05-22-2016, 04:21 PM | #4 |
chevy2tom, the bench saw for sale on craigslist looks a bit different:
It's out of an '81 C10
05-22-2016, 08:11 PM | #5 |
Measure hole to hole on your truck floor & transfer the measurements to a piece of cardboard & bring it with to look @ the new seat also measure door to door to make sure it'll fit but it should.
05-22-2016, 11:23 PM | #6 |
60-66 Nut
The seat mounts for the '72-'87 seats are completely different from the '60-'66 seat mounting. The '88-'98 seats like chevy2tom posted are a much easier bolt in seat.
05-22-2016, 11:34 PM | #7 | |
05-23-2016, 05:47 PM | #8 |
1961 crewcab
do you know if the brackets from the 60-66 seat just bolt on to the 73-87? that is what I was going to do for my crew cab, I will check it out tomorrow for you guys. I thought they did,
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-23-2016, 07:07 PM | #9 |
Following
05-23-2016, 11:36 PM | #10 |
60-66 Nut
Sorry but I do not know Jon. I have never tried it.
05-24-2016, 07:11 PM | #11 | |
1961 crewcab
the 60-66 seat riser lifts up into the back of the seat. the back of the 73-81 seat is flat, so the 60-66 seat riser would have to be modified to work, regardless looks like a lot of work to make it work. I was sure my 63 had a 73-87 seat in it because it is not a 60-66 seat- it does not fold forward- but now I am not sure what is in it... def. not a 73-87
05-24-2016, 11:54 PM | #12 |
1961 crewcab
here are the pics: the red seat is a 64, and as you can see the mount to the rear goes much deeper than the rear section of the blue 73-87 seat next to it.
also the gray seat in my 63: anyone recognize it? it does not fold forward, it is screwed tight, but the 60-66 seat tracks bolted right up to it. I thought it was a 73-87, maybe it is a 67-72?
05-25-2016, 12:37 AM | #13 |
The 73-87 seats could be made to work easily enough. The brackets could simply be bent to sit on the floor of the 60-66 but it would still sit way too low. The best option would be to make something to bolt on that functions as a riser to lift the seat and an adapter so nothing has to be modified.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
05-25-2016, 12:37 AM | #14 |
You can usually tell the square body seats as the cusion swell out on the sides after they get past the seat belt retractor. They look kinda funky in our trucks to me because of that.
