Windshield leak
Found my water leak, how is this fixed, or what do i tell the guy to do different when he takes it out to try and fix this? I dont know if he used windshield sealer, would that do it?
1972 GMC Sierra 'Ol Blue' K25 350/400 1999 GMC Sierra 'Ol Betsy' K15 5.3L Though I walk through the valley in the shadow of rice i will fear no turbo, for torque art with me. Thy rods and thy crankshaft, they comfort me. |
Re: Windshield leak
It leaks down the kick panel
Re: Windshield leak
mine was leaking there I replaced the gasket with a precision gasket no leak there now I got something in the cowel area on driver side I'm trying to track down
![]() Join Date: Apr 2011
Re: Windshield leak
Are you sure the leak is there and that isn't just water pooling up there? Usually they leak up top, and seeing water on the kick panel kind of tells me that's what is happening. If he uses more sealer when he reinstalls it, that should do it unless you have metal rot under there (which I assume you already checked for when you replaced it the last time).
Re: Windshield leak
Yeah all of the rot was taken care off, which there wasnt too much thankfully. Maybe he just needs to use more sealer... If it was the top how would that be getting water to the bottom/inside of the rubber?
![]() Join Date: Jan 2001
Re: Windshield leak
Make sure it's a flow-grade butyl sealer. Never use silicone to seal a windshield.
Re: Windshield leak
I'm not saying your windshield *is* leaking from the top, just that they normally do leak there. Have you tried directing the stream of water to different parts of the windshield? If you have a syringe, try squirting water at different areas and see if it leaks through.
Or just bring it back to your glass man and have him fix it.... |
Re: Windshield leak
they must have had leaking problems from day one because the assembly manual ha a whole section on testing vehicles for leakes.
