1962 C10 Engine Wiring
If you guys could help a brother out who is worn out and really needs to wrap things up before my truck goes in for inspection tomorrow evening
So please (I'm begging) do not flame me or direct me to the FAQ or electrical section I've looked and could not find a 1962 C10 Engine Harness Schematic for 6 cylinder with Lights If you can help that would be great if not - peace. I have a 1962 C10 with stock instrument panel with lights (not gauges) I've installed a 1964 283 V8 with points style distributor and a Pertronix conversion kit. I'm trying to figure out how to make the engine harness work. I'm told I need to eliminate (or go ahead) of the resistive wire to get the full 12 volts to the distributor. White / Orange - Is that the resistive wire? Pink - R on Starter Solenoid Violet - S on Starter Solenoid Dark Blue - Oil Pressure Sender Dark Green - Temp Sender Light Green - (Alternate) Temp Sender TIA |
![]() Join Date: Feb 2016
Re: 1962 C10 Engine Wiring
Give me a minute I'll get my schematic out and check. I recently rewired mine.
Did the instructions on your pertronix tell you to eliminate resistor? if I recall some do some don't. the resisted wire should have a white cloth style insulation on it. you should not need to hook up wire to r terminal on solenoid this supplies 12 volts to coil on cranking for points type ign. violet is the s term. dark blue is oil. dark green should be temp. as far as light green do you have a cold idiot light? I don't remember. hope this helps
Just follow the wire originally connected to the + on coil. Just trace it all the way back to the firewall and replace it with 14g wire.
#6 | |
I'm not sure either on the cold light I'll be honest - it's been four years and my truck did not have wiring from the firewall forward when I got it I gotta check that dash panel out to be certain - drawing a blank |
#8 | |
I have Dark Green, Dark Blue, Violet, Pink, and Light Green at the truck's dash harness firewall connection for the Engine Harness. |
Ok found diagram pink does go to r term on starter light green dark green both go to temp sender . is the pink wire piggy backed with the white orange?
if you battery is hooked up test voltage at pink wire with key on
pink wire has to be resisted according to diagram
Ok last post pink goes from ign sw. to r term on starter then there is a jumper wire that goes from r terminal to coil + this tells me that pink is resisted and in crank position solenoid shoots 12v to coil. sorry for confusion this is quite different from later c10s.
#13 | |
