Engine gets hung up
Ok so while I have been doing body work and the engine has sat, for about a year. I re-wired it and when I finally startered it sounded like something bouncing around under the valve cover so I took look and everything seemed ok, with the covers off I tried and rotate the engine by hand. It goes to a point then seems to get hung up and will not move. I can rotate back and then go toward and it goes a little and does the same thing again. And suggestions? ? I have starated to break her down just seeing if you all had any ideas what the issue is?
![]() Join Date: Jan 2011
Re: Engine gets hung up
Sounds like it may have a valve stuck.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Post Whore
![]() Join Date: Mar 2013
Sticky valve is a good possibility....any bent push rods?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I am not sure yet. In the process to tearing it apart. Just worried its bottom end.
Active Member
![]() Join Date: Jul 2007
I,m not so sure it's a valve problem in a stock engine but I would definitely start by removing the valve covers and carefully checking the rocker arm movement to see if you can determine at which point the engine gets hung up. See if it's at the same spot every time. You may be able to determine if it's a particular piston.
Definitely don't try to start it until you find out what is causing it though. I've had a rod bearing come loose on one engine and cause major damage. Also had a valve seat come loose in another making an awful racket.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Bent push rod was the issue. Not sure if there is any other damage yet. Hopefully worse case, wiped my cam.
*** That's interesting ***
Next question is, why is that valve hung up?
Best case scenario...if you didn't run it very long, might just need to replace the lifter and pushrod, after fixing the valve.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
Active Member
Great! The first two responses hit it on the nail. Hopefully it's just a stuck valve and not more. The way you described the problem where the engine wouldn't move is the reason I suspected something else.
If it's a stuck valve, I once had one a F@rd truck engine that bent a push rod. Engine still ran but really rough and noisy. I used transmission fluid to unstick it. I poured some fluid on the stem and continuously tapped the spring until it broke free. Good luck.
I am definitely getting a valve job locally. If nothing is wrong in the bottom end just going to put a little beefer cam, push rods and lifters. What yawl thoughts on that approach?
And did not run it long at all. Like minutes because of the noise it was making. Actually the truck never even went in gear once I heard the noise
Well if you are doing a cam anyways, just have them check the cam and bad lifter. As long as you didn't wipe a lobe and spread metal all through the engine, you should be OK.
I figured since I amin there I would beef up the cam and put some roller lifters in there. It's not to much money and heCo it's already apart.
#13 | ||
"I ain't nobody, dork."
Is this a recently rebuilt engine? The lifter valley looks pretty clean.
If it's a 40 year old high mileage engine and you have a 3 angle valve job done to the heads it will start sucking oil past the piston rings and will smoke. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#14 |
It was rebuilt by PO. It just sat for a while when I was doing all the rust repair/body work.
#15 |
![]() Join Date: Sep 2005
mine did the same thing sat for a year vavle stuck int eh guide and it pulled the vavle guide out of the head and bent a pushrod
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#16 |
#17 |
I have no idea i just swaped in an ls and gave the motor to a friend
#18 |
Active Member
It may not have done any more damage. Just make sure there aren't any others that are stuck or sticky.
On the engine I mentioned above that had the bent push rod, there was no other damage. I drove it for several months before selling it.
#19 |
Thank you everyone for the advice and respond but, the bottom end was a mess. Scared cylinders, metal everywhere. So I think I am not going to put the money and time into this engine. Looking into a whites performance 383 stroker.
