Old 05-22-2016, 07:50 PM   #1
bobdavis2010
Help finding gas tank 59 Chevy apache
Hello guys I need help? I'm looking for a gas tank for my truck it has a motor out of a 96 Chevy truck 5.7 fuel injected vortec I see gas tanks for $400 but I don't have that kind of money I was going to go to the junk yard and try and find one any ideas is any body running a tank from another vehicle
bobdavis2010 is offline   Reply With Quote
Old 05-22-2016, 08:36 PM   #2
Coupeguy2001
Coupeguy2001's Avatar
Re: Help finding gas tank 59 Chevy apache
fuel injection tanks are the expensive part.
In our trucks, the frame rails are too close together to use a conventional tank out of something as is.
You might have to buy a tank that fits, then adapt it to a pump. You can also use the mustang tank, and on Ebay, buy a submersible pump for $20 or so, make a bracket for it that is anchored to the sender unit and then place the ring on the sender with a new o ring.
Coupeguy2001 is offline   Reply With Quote
Old 05-22-2016, 08:46 PM   #3
bobdavis2010
What year of mustang tank ? Would that tank have a return
Old 05-24-2016, 12:12 PM   #4
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i don't know about the year, but a return can be added to any tank pretty easily.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 05-24-2016, 05:14 PM   #5
Dave0
I put a 01 camaro tank in my 55 second series. Had to trim the bottom of one rail. But I got away from having the bed filler. Plus I got a complete tank and a extra pump for 100
Theres a build thread on this page now..
Dave0 is offline   Reply With Quote
Old 05-24-2016, 05:22 PM   #6
bobdavis2010
Nice thanks
Old 05-24-2016, 05:37 PM   #7
Dave0
16.5 gallons btw
Old 05-24-2016, 06:32 PM   #8
tmoble
Dave, interested in more info on this tank. Which build thread is it? Have you got a link to it? I see there's several build sections.
tmoble is offline   Reply With Quote
Old 05-24-2016, 06:35 PM   #9
Dave0
Not really a build thread but more of just a bunch of pics. Questions from me too
http://67-72chevytrucks.com/vboard/s...d.php?t=702899
Old 05-24-2016, 08:46 PM   #10
Coupeguy2001
Dave,
Now I have questions.
1. Why did you take the original spring perches out if you put different ones back in same place?
2. Was that a long bed frame cut short?
3. is that a plastic tank?
4. Where are you going to put your exhaust?
Old 05-24-2016, 08:54 PM   #11
Dave0
Originally Posted by Coupeguy2001 View Post
Dave,
1 to put wider (s10 springs in)
2 short bed
3 poly tank
4 dump out before axle...
Old 05-24-2016, 09:24 PM   #12
Coupeguy2001
what advantage does the S 10 springs provide?
I had turn downs before, and they just made the tailgate dirty.
(and everything from axle back).
Old 05-24-2016, 09:50 PM   #13
Dave0
Better ride, 2.5 inches wide vs 2inch... Plus I used a S10 4X4 rear end, that has 2.5 inch perches on it..
Im going to blow it out the side. Not turn it down and blow **** all over my truck...
Old 05-25-2016, 04:05 AM   #14
tmoble
Thanks Dave. I've been into that thread several times but not lately. That Camaro tank deal looks like a winner.
Old 05-27-2016, 05:37 PM   #15
Dave0
Another note. The gas tank will fit in if you dont trim the lt rail. I will just hang down further...
Also, I took the rear cross member out and spread the rails open a 1/8 inch a piece (1/4 inch total) And it really helps with fit! But you would have to ream out the holes for the bed to bolt on the rear...
Old 05-28-2016, 06:37 PM   #16
bobdavis2010
Any tips on trying to mount this tank??
