Old 05-22-2016, 09:46 PM   #1
custom10nut
custom10nut's Avatar
Underhood light
Last week I found an under hood light from a late model truck. It is a mercury switch set up that turns on when the hood is lifted an off when closed. I'm trying to figure out how to mount it without drilling any holes. I think I've got it figured out. I have to fabricate a bracket that will attach using one of the existing holes and enable me to snap the light into. Has anyone else have this setup in their truck? It's not that I plan on working on the truck in the dark but it's just kind cool to have the light in the parking lot at a cruise-in.
custom10nut is offline   Reply With Quote
Old 05-22-2016, 11:14 PM   #2
mike16
Re: Underhood light
after you mount it. wait until its dark outand go see if the under hood lite remains on when your hood is closed.
I installed one on a car and after that the battery was dead every morning. I did not make the connection and replaced numerous things including the battery, alternator ign switch ect. then one night I came home to find a glowing lite under the hood. it was that under hood lite all along. I repositioned it correctly and the problem went away.
mike16 is offline   Reply With Quote
Old 05-23-2016, 12:35 AM   #3
custom10nut
Re: Underhood light
I know what you're saying. When tilting it up and down, it works as it should but we'll see. If it gives me problems? Oh well , I didn't give much for it.
Old 05-23-2016, 06:43 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Underhood light
I bought 2 of the mercury switches at the parts store and mounted them under the hood.
They are nice to have when your checking the levels on the sticks.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
