400 Turbo to 700R install
Looking for information on going from my 400 Turbo with electronic kickdown to a 700R. I am running 3:73 gears and really wanting that higher gear for interstate driving. Needing parts suppliers, how to's etc. Wasn't sure of past threads on here that could help. Not wanting to do a switch either to lock up converter. Any input would be appreciated.
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
Re: 400 Turbo to 700R install
If you currently don't have a good throttle linkage bracket that has the correct mount for the detent cable, you should buy one. They ensure that you have correct angle and length of travel on the cable. You will need to purchase the correct attaching stud for your carb as well.
If you pull heavy trailers with this truck the th400 is a much better transmission, and there are other overdrive options available. |
Check out my build page, post 25, I swapped to 700r4 from TH350. I used the TCI lockup kit from Jegs that runs under vacuum so I didn't have to use a switch and I had to purchase an adapter for my carb throttle. The adapter I got was for a Holley carb and I know there were two different types either for Holley or Edelbrock so purchase for which ever you have. Also my TH350 was a long tail so I had to have my Driveshaft shortened. As far as installation goes it was straight forward it bolted up the same I just had to move my cross member back a couple inches. It was well worth it for me just to be running at lower RPM's at highway speeds.
-Mike 1970 C10 Stepside 350/700r4 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707 |
I did this swap on my BBC truck when i tore it down to the frame.
www.bowtieoverdrives.com I purchased the crossmember, which has a new parking brake lever hook up position, and the TV-MADE-EZ kit, which was machined correctly for my carb. Their website has a few links that aren't the greatest, but you'll manage to get through it. If you're going from VSS to cable speedo i ordered ATP-Y803, and it was the correct length. Use a tire height calculator and find a website with the correct drive/driven gears for your setup. Take the tail off the transmission and put the gears in. As far as shifting is concerned, i tried both the Lokar linkage kit and the cable kit. I found the cable kit ACA-1804 to be much more adjustable, i also purchased the back up-reverse light kit to use as the Neutral Safety switch and kept the reverse lights on the column safety switch. The throttle cable (i have a '72) was also purchased from them as the universal cable, as the cable i ordered from the big thick catalogue of crap supplier (i'm sure you know who that is) didn't fit worth a darn, and i have an Edelbrock carb. I used the universal cable and the one that didn't work and built a hybrid unit that had the look of the original and adjustability of the universal with the correct ends. I also put the Torque converter electric lock up in my truck, which kicks off when the brakes are applied. You could order this and install it in the transmission and leave it disconnected, and then if you ever want it, it would be very easy to hook up. Last edited by Howitzer; 05-23-2016 at 12:12 PM. |
#5 | |
![]() ![]() Join Date: Sep 2008
Pretty much everything I could say has been said.
We are taking another one in this week for the Turbo 400 to 700R4 swap. Luckily we have a guy that builds our 700r's and installs them. You will love it. I have a 700R4 in my BB Longhorn with 3.73 gears and it works great. Now I can run with any traffic on the Interstate. The lower low works good when towing also.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#7 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
What's your tire size?
I'm still running the stock 3.08 gears, it does lag a little off the line and I plan on swapping to 3.73 soon but at around 70 MPH my RPM's are around 2600 to 2650 with a 28" tire height. Im running 15" steelies with a 225/75 tire.
This will let you calculate speedometer gears.
http://www.tciauto.com/tc/speedometer-gear-calculator
255/70/15 and planning on on 275/60/15 in the near future
Its a Truck Thing......
You will need a new yoke for the driveshaft, 400's are bigger. I used PATC to get all the parts for the speedometer. Since you are running 3.73's they should have both gears you need. They have the calculator on their site also.
If you are going to tow, I suggest adding in another trans cooler in addition to the one in the radiator. The lock up is up to you, I added a switch and also used the correct brake light switch. I am running 3.42 and 275-60-15's. Shoot me a PM if you need any further info. https://transmissioncenter.net/ Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
