Grandpa in the rustmobile...
TH400 to 3spd manual crossmember swap
Im sliding a shortbed frame under my 1968 c10 equipped with a 3spd manaul trans. The shortbed frame has an automatic transmission crossmember bolted to it. I unbolted it and cut the rivits off my 3 spd trans crossmember in the longbed, lined it up on the shortbed frame and there are no holes for it (unless i got it on backwards).
Should there be predrilled holes in the crossmember for a 3 spd/manual trans member? Thank you guys I appreciate it
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
![]() Join Date: Jun 2005
Re: TH400 to 3spd manual crossmember swap
When you say "predrilled holes in the crossmember", which crossmember are you referring to? Did you mean predrilled holes in the frame?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Figured it out. The swb 1969 frame has holes for auto and manual transmission crossmembers.
Thanks guys!
