Fuel Gauge Issue
I have a 1972 Chevy C10. I have an issue with my fuel gauge that i just can not seem to understand. My gauge shows pin well below the E. When i start the truck it jumps up a little so i know there is power to it. I took it apart on my own and forced the pin back above the E, but by the time i connected the cluster back up, the pin dropped well below the E again. Do you have any idea what this may be? I appreciate any assistance with this.
#2 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Fuel Gauge Issue
The gauge sender terminal may also be grounded which would cause the gauge to read empty.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
It shows well below E. I am going to try and disconnect the fuel sender wire and crank it when i go to lunch in a few hours and see what it does. I also will take a picture and post it here soon to show you what it looks like. I have never seen a gauge go below E this much. Thanks for your Reply VetteVet.
