Old 05-24-2016, 11:28 AM   #1
wannabefastcrf
LS swap remove voltage regulator
Can someone point me or explain where I can find info on this.
I found this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
When everyone is swapping in a LS motor do you need to connect the blue wire to the alternator or just connect the two wires together on the voltage regulator and a power wire from the main stud on the alternator to the battery
wannabefastcrf is offline   Reply With Quote
Old 05-27-2016, 11:20 AM   #2
Matt Cramer
Re: LS swap remove voltage regulator
If using the alternator that came with an LS motor, it will have its own voltage regulator built in. It just needs a charging lamp connection on the L terminal.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 05-27-2016, 12:07 PM   #3
MalibuSSwagon
If using the factory PCM the regulator in the alternator is controlled by the engine computer...you could likely ditch the external regulator all together.
MalibuSSwagon is offline   Reply With Quote
