Porterbuilt Big Block chevy
Anyone running the Porterbuilt with a big block Chevy Mark IV engine?
I have a Porterbuilt level 3 ordered and I just had a 496 big block built for it but I have never seen a big block with porterbuilt. any input on how the fit is? It must fit, the big block was a option when ordering
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Re: Porterbuilt Big Block chevy
I've done a 502 ramjet install with a pb dm that came with the truck, not impressed with there customer service.
Did you happen to have to notch your oil pan to clear the rack steering?...I saw one that had to. There is VERY little on Big block DM
No I lowered the rack which will help with the bump steer ( the more you keep your rack parallel the better for this) My main goal is to get the truck to handle so i lowered the motor so the pan is 3/4 " above the dm. and I moved the engine back 1 1/4.
I'm running a level 3 dropmember with a 396, the rack and pan are close but with the motor/trans dropping back at 5 degrees for the driveshafts it brings it up and off the rack, although not by much.
Great to know. I'm about ready to set my motor. I seems not a lot of people put Big Blocks with the Porterbuilds. What Headers did you use?
I'm using Hedman headers, Porterbuilt recommended these. Perfect (Tight) fit, no bending or "massaging" needed. The driver side collectors face straight down on exit so i had to buy a hard 90 degree stainless elbow to keep things tucked. i can only imagine why people stray away from the monsters, everything is tight....
Hey,Grambo-I'd like to see your truck sometime. I have a 66 GMC 454 in Buxton Maine.
Agree
I'm gonna try and attach some photos to give you guys an idea of what I'm starting with and where I've gotten to
Another one.
Before I got going.
#13 |
That looks great!
#14 |
what headers are those?....any photo of the oil pan clearance to the rack steering
#15 |
lowered rack 1 1/2"
#16 |
Did you have to make clearance for your valve covers against the firewall?..Photos?
