Old 05-24-2016, 03:37 PM   #1
Bowtiguy
Bowtiguy's Avatar
NEW Dark Grey Vinyl flooring 67-72 high hump
<<<<<<<SOLD>>>>>>>>>>
ust as the title says. This is NEW and uninstalled. It includes jute ( insulation) for the front floor boards. It is for high humps and has extended length for gas tank delete or you can trim it in front of the tank. $150 + shipping new from stockinteriors. I decided to go with carpet instead.
$100 local pick up gets it. Located just north of Denver and west of Boulder about 15 minutes.
1967-1972 Chevy Full Size Truck, Standard Cab custom molded vinyl flooring is Heat and Pressure Molded to the original floor pan. It is made with Top Quality materials for a heavy duty and long lasting product. This aftermarket vinyl flooring fits your 1967-1972 Chevy Full Size Truck, Standard Cab 2 WD 4 Speed or 4WD (High Tunnel) just like OEM when installed and is Guaranteed to fit, with no defects. May require trimming to install. See our Auto Carpet Install Instructions for details. There are times when carpeting is not the appropriate floor covering for a vehicle. From the pickup trucks and SUVs that spend their time off-road or at the construction site to a taxi cab shuttling people through the city, our vinyl flooring is the heavy duty alternative. This item will not have the holes cut and may be shipped slightly oversized around the edges. This item is custom made after the order is placed, and typically ships within 2 business days.
•Heavy Duty vinyl is long lasting
•Rigid enough to hold it's molded shape
•Easy to trim during installation
•Vacuum molded for Precise Fit
•Cleans up easy!
•Comes in a variety of colors
•Features a non-skid textured surface
•Jute padding is included, but not attached
Bowtiguy is offline   Reply With Quote
Old 05-26-2016, 09:16 PM   #2
Bowtiguy
Bowtiguy's Avatar
Re: NEW Dark Grey Vinyl flooring 67-72 high hump
Sold..........
