05-24-2016, 11:14 PM | #1 |
68K20 steering box seal kit?
1968 K20 manual steering
where can I get a manual steering seal kit? Looking to reseal my manual steering box. need a gasket set anybody know who sells gasket sets? refilled my 68K20's steering box with STP and moly. Noticed this morning it was leaking from the adjustment cover. I;m pulling it off to clean it up. I figure to put new gaskets on it while its out. dont need rebuilt just resealed. |
05-31-2016, 02:33 AM | #2 |
Re: 68K20 steering box seal kit?
anybody?
06-04-2016, 02:28 PM | #3 |
It took me forever to find a manual 4x4 box and when I did it was actually cheaper to buy new power steering everything than a new manual box. Can't really help but try ebay? That's where I found the box for like 200 or 225 bucks. It was NOS though...
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
06-05-2016, 08:59 AM | #4 |
Maybe test your patience and make one from a sheet of gasket material
06-05-2016, 01:00 PM | #5 | |
I need a seal kit. It involves more than a simple paper gasket. there is a steering shaft that goes into the box and the pitman arm shaft that exits the box. both,presumably, have seals, neither of which is made of paper. unless I am mistaken. Did I pass the patience test? I dont usually, but I'm trying. |
06-05-2016, 05:41 PM | #6 |
Your first post mentioned gasket sets,... twice. I couldn't help you on the seal part, so I figured I would try to help you with the gasket part, but I guess I was no help at all. Good luck with the reseal
06-05-2016, 08:03 PM | #7 |
Dont know which to call it so I mentioned bothe seal kits and gasket kits. figured they were the same thing sortof like an engine gasket set has seals , Too further clairify, a'll state again gasket or seal kit, to reseal the box.
somebody point me in the right direction and I think I can handle it from there. thanks for your help. |
06-06-2016, 02:18 AM | #8 |
There is a few companies like redhead and lee power steering that rebuild boxes,I would talk to them see if they got the gaskets you need.
06-06-2016, 11:53 AM | #9 |
anybody know if the seal has a # on it? should be easy to find one if so.
1961 chevy K10 my build is------------61K10 build |
06-07-2016, 12:46 AM | #10 |
