Old 03-28-2002, 02:34 PM   #1
THOR 50
Over worked under paid
THOR 50's Avatar
Question Brake pedal squeak
Is there a replacement bushing. for the brake pedal? My pedal squeaks really bad.
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 03-28-2002, 03:36 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
spray wd40 or pb blaster on the shaft and busgins and spring ends, that will cure it, it should be done everyonce in a while anywas as maintenance to keep the bushins from wearing, but they dotn usually anyways, theyre pretty tough i have found..
good luck
Randy- Lincoln, IL
randy@ccaonline.com
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28 H.O. 305 L69 700R4 GT4 3.73
- 1984 Firebird SE 2.8L T-5 GT4 3.73
-1981 Cutlass Supreme, dunno what im gonna do with it yet...
-79 G20 pass van, 350/th350/10bolt
*Paint is overrated
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-29-2002, 07:42 PM   #3
THOR 50
THOR 50's Avatar
Question
Thanks Randy but didn't this originally have grease along the pivet shaft.I'm pretty sure when I removed my clutch pedal from the assembly there was alot of grease. If I use a spay lub won't that break down the grease. Also the plastic is really worn. I could use a replacement. Any ideas where to get one new.
Roger
Old 03-29-2002, 09:58 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Post
I have never had this problem but,if you want to upgrade the bushing to brass/bronze you can probably find one at one of the supply houses that sells machine shop tooling ect.They will usually carry stock sizes of bushings and should be able to find a suitable one.Remember to measure legnth,ID and OD. Give a couple places a call, one of them may even carry plastic bushing material.
Deland does Chevys 68Chevy panel(LIZ)
"A man and his truck,it's a beautiful thing"
"I have the body of a god,unfortunately it's Budda"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-29-2002, 10:08 PM   #5
BubbaGreen
Post
Those plastic bushings are very thin material, I dont think a brass/bronze one
is made that thin (could be wrong).
Just took mine apart as well, mainly because
I am installing power brakes and wanted to
clean things up a bit. My old master cylinder leaked brake fluid down both the inner and outer firewall, taking paint and
all with it. There was quite a bit of
'dried' up grease in those bushings which I
will re-grease with hi-temp bearing grease.
but the bushings when removed were in really
good shape.
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 03-29-2002, 11:27 PM   #6
TxGary
TxGary's Avatar
Post
Just bought those bushings this week. Still a GM item. Brake pedal bushing #346383 $2.95 ea. Clutch pedal bushing #346382 Can be ordered from any General Motors Parts Dept.
71 C-10 SWB Frame up Restoration in progress.
69 C-30 Motorhome Restoration in progress.
00 GMC 2500 Daily driver
2002 Kia Rio Daily driver
2002 18'Texas Bragg car hauler
P/O 70-72 Chevy Trucks
My Photos:
http://photos.yahoo.com/txgary4361
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is online now   Reply With Quote
Old 03-30-2002, 12:17 AM   #7
67 LWB
Post
damn i wish i would of known that. I had to replace mine and the gm dealer and a couple of other places i went to could not find one. I ended up taking the pedal and shaft down to a machine shop and had some brass ones made and installed for about $20.
oh well live and learn.
'67 C10 LWB FLEETSIDE, WEAK 305 UNTIL I CAN GET THE 400SB REBUILT, TH400, 3.73 REAR
SALEM, OREGON
http://www.freephoto-i.net/browse.ph...e=DCP_0003.JPG
'67 C10 LWB FLEETSIDE, WEAK 305 , TH400, 3.73 REAR
COLORADO SPRINGS, CO.
67 LWB is offline   Reply With Quote
