View Poll Results: Run an oil bath breather | |||
Restore and run the oil bath breather to remain stock |
21 | 75.00% |
Run a stock type paper filter breather |
2 | 7.14% |
Modify the oil bath to accept a paper filter to keep stock look. |
5 | 17.86% |
Voters: 28. You may not vote on this poll |
Would you run an oil bath air breather?
My 67 came stock with a oil bath breather and 327. My build is completely 67 72 era parts only.this truck will not drive often just to cruise around. I have read all the pros and cons of these. Want to keep the stock look. What would you do.
Re: Would you run an oil bath air breather?
The older I get the more I tend to stay stock with what the truck came with, I just appreciate them more than a modified, I enjoyed that in my early 20's before children, now I just want to preserve and make them last. Nuttin wrong with an oil bath!!!
![]() Join Date: Apr 2007
I had a 61 Gmc 3500 that had one on a 305 V6. No problems ever and the oil always got filthy between changes so it must work good. Also had them on old school air cooled VW bugs, again worked great.
#4 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Would I keep it? Yep -- cleaned up, wiped down, and on a shelf. I fooled with too many of those when I was a kid and worked in a service station. ![]()
There was nothing wrong with them back then so I would clean it up and use it.
I can't say I've ever been too a car show and seen one on this generation of truck I dont even know anyone who still uses one. I don't know much about them but I don't think there was anything wrong with them then so I don't see anything wrong with them now. Besides you truck was made with it why not leave it be. I have one also not gen correct but I still may use it to be differnt.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
The only reason I would run one is for originality. The paper cartridge filter cleans better & is less restrictive. The paper filter was developed for dirt track racing & shortly after was adapted by all the car cos.
327 2bbl or four bbl?
The Older Generation
I voted use it. I thought that you had already restored one of these. Maybe my mind is going South on me.... ![]() LockDoc
I did. I have 2 now. I just don't want to destroy one making it work with the peper filter.
#11 | |
LockDoc
Junior Member
Nothing wrong with an oil bath air cleaner for a cruiser. Just like drum brakes are to disc brakes.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#13 |
Oil bath are superior to paper at cleaning the air.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#14 |
I have one on my 68 stepper. Works really good.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#15 |
#16 |
never seen one how does it work any pics
#17 |
Here are pictures of the one I restored. I have 2. You fill the base up with oil to the oil level. The air travels up thru the air cleaner lid and then drops suddenly. Then goes back up thru the mesh in the circular holes. As it goes up supposedly gravity makes the dirt particles fall into the oil.
#18 |
This is my other one. Same thing except this one has a removable plastic liner thar would make it easier to clean out the dirty oil. I was going to make this one accept a paper filter but I might not.
#19 |
Can anyone currently using one let me know if the intake gets all slimy with oil residue?
#20 |
![]() Join Date: Nov 2004
I was always curious if they have a smell, like you always smells oil when you walk passed the truck.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#21 |
So i did a little research as i have no experience with oil baths and i like to learn. From what i was reading on a forum of a bunch of guys restoring pre 1940s cars they say the oil baths dont work well at low cruising RPM's . The reason behind this is that the air velocity is to low at low RPM and small particles dust bugs what have you can actually make the 180 degree turn and end up in your intake and carb. Turns out its not just gravity doing the work of cleaning the air. Air velocity plays a large part. At a high rpm the particles in the air have to much velocity to make the turn and end up in the oil bath . (pretty intuitive when you think about it) . Apparently another downfall to the oil bath is over time you accumulate oil vapor in your carburetor intake and intake runners of the heads. This oil vapor is enough to stick to the walls and build up over time lowering your octane rating on your intake charge because the fuel is now mixing with air, oil, and oil vapor.
#22 |
that is very good info. Thank you for that. I does make good sense. I wonder if when on low rpm would the oiled mesh in the lid not catch some particles as well?
