Pedal Mounts.
If you look at Burnsman's thread here
http://67-72chevytrucks.com/vboard/s...threadid=70751 you see the typical pedal mount for the brake, and in the case of a standard tranny, the clutch pedal. How many have the OTHER mount, the one that has the larger brace on top (the triangle pointing to the right in Burnsman's photo) and the heavier clutch spring extending down the length of the pedal shaft from the top brace, not back to the rear of the mount (as Burnsman's does)? There is a diagram of both mounts about a quarter of the way through the Assembly Manual, which lists the OTHER mount for the 40-60 series, but that's the one I have in my K-10. I curious to see how many others have the "heavier" mount.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Firefighter
A friend of mine had the heavier one in his 69 k10, until we put in an automatic. Pretty sure that my 67 GMC has the heavier mount also but will have to look in the morning.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
ran out of money
i got the heavy one on my 71 c/10 with a 3 speed
Modify everything, leave nothing alone!~ ![]() ![]() |
