Old 05-26-2016, 12:48 PM   #1
Flysocal
1954 speaker ideas
Mocking up my cab and need ideas on where to put my speakers. Kick panels would be good but my left side is occupied by e-brake and cup holder. Rear cab corners are occupied by retracting 3-point seatbelt. The original spot has room for 1 5x7 which is fine I guess. I'm not going to run a bangin system. No amp no sub just a basic system for radio. Any ideas how to mount a 5x7 speakers in original spot? Or any better ideas. It would be nice to run 2 speakers. Mounted controller in glove box.
Flysocal is offline   Reply With Quote
Old 05-26-2016, 01:47 PM   #2
mr48chev
mr48chev's Avatar
Re: 1954 speaker ideas
With all the different sizes of speakers and speaker boxes I'd think that you would have and easy time of it. It just depends on how much of a sound system you want and how many speakers you want. Combo speaker behind the speaker grill, Mids mounted high on the kick panels and maybe a couple of small tweeters up in the corners of the headliner. Then your rear speakers in the cab corners with a sub somewhere.
On mine next time around I don't want one speaker in a position where you can see it from outside the truck unless it is behind a speaker grill in the dash.
My ongoing truck projects:
Old 05-26-2016, 02:56 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
I've got 2 -5" round speakers and a stock radio in my 81..its plenty loud and clear..even with my exhaust dumping in front of the axle..I stuck em behind the seat..the small size makes them easier to put in tight spots..
Old 05-26-2016, 04:34 PM   #4
Coach529
Coach529's Avatar
I have a pretty good sound system in mine. Deck, Sub and amp under the seat. 6 x 9's behind the seat and a couple 4" round speakers in the stock location. Nothing is seen when you look through the window.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-26-2016, 06:34 PM   #5
Flysocal
Hey Coach how did you mount the 4" speakers in the dash? I'm looking at buying these. 2 4" is better than 1 5x7 I think.
