Those of you who are 2WD lowered on 8" Rally's...wheel spacers?
Especially stepside owners. I have a 78 SCSB stepside that I will be running 8" rally wheels on. My wheels look very inset compared to other trucks running these same wheels. I was curious if anybody here was using spacers to push their wheels out some? I want to run 275/60R15s in the back, and I think I will need spacers regardless, as it seems like the tire would hit the inner fender well.
Thanks in advance |
Diggin The SquareLife
Re: Those of you who are 2WD lowered on 8" Rally's...wheel spacers?
Havent seen anybody run spacers for rallys an if u think they look inset get some 15x10s for the rear
Cruzzzn' Vet
With a 5" BS
ive got a lwb running 8's all the way around with 245/60-15 front and 275/60-15 rear. been considering 1/2 to 1 inch spacers on the rear myself.
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
I just did this very thing on my 86 short wide bed. Get 1" spacers and you'll be all set. My setup is 255/60 on 7" rally's up front. 275/60 on 8s in the rear with 1" spacers.
Passenger side.
Where did you get the 1" spacers?
I have a flip kit and 2 inch drop shackles, running 15x8 rallies and 295/50/15's. No rub but thought about 1" spacers just to bring the tire out.
.....__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
#10 | |
The need for spacers will depend on the backspacing of the wheel being used. Some wheels might require their use; some won't.
#11 | ||
Yes, just stock 73-87 Truck/Suburban 5 lug rally wheels. |
I got my spacers on eBay for around 40 bucks shipped. Be sure that the center bore is 82mm or bigger. The hub centric jeep spacers will NOT fit as the center bore is too small. 1" spacers do not require you to cut the factory lug studs down, just bolt them on and bolt the wheel to the spacer.
I have 1/4"-3/8" clearance from the factory non rolled fenderwell lip to the outermost bubble of sidewall bulge. Hope this helps. |
#13 |
Here's the exact ones I got. On sale now for ten dollars less than what I paid.
#14 |
Thank you so much for the info. Looks like they may be out of stock since I cannot find that particular one. They do list a 1.5.
#15 |
#16 |
If I remember correctly, about 3/4 to 1" of clearance
#17 |
#18 |
Side pic for blazer2007
#19 |
Looks like im gunna get a set, looks much better and I don't have to buy 10" rims!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
#20 |
I have 17" on my stepper put 1" spacers on mine.
