#1 | |
14 bolt full floater to a '81 k20
Anyone know if the Second design 14 bolt ('89 and up)SRW/FF will have the same axle perches and spacing as a '81 k20
Im looking for a 14 bolt ff with slide off drums (you dont have to remove hub nuts and hub to pull the brake drum) From 14 bolt bible: Quote:
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
Re: 14 bolt full floater to a '81 k20
Perch spacing is different, but should work once repositioned.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
If it has slide off drums, that is a semi-float axle. Still strong unless you have a hard core heavy foot. And spacing is different, but relocating isn't hard
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
Apparently '89 and later full floaters have slide off drums too.
http://www.pirate4x4.com/tech/billav...ble/index.html My '99 Dodge CTD dana 70 has slide off drums also
user # 2756
![]() Join Date: Jun 2001
You could look for a dana 60 from a early GMC. Mine has slide off drums in my 1970. The spring perches would be the same.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
This is wrong. It's true that the older ones had press drums, and semi floaters had slip off. But I have one from a van that is a full float and slip drums. Not sure the rhyme or reason why some got pressed and some slip. I had one from a 93 slip, and one that was in my 97 that was pressed. Not always a brake thing either...
Same here. I had both ways with drums on 14-bolt full-floaters. One was a '92 and the other was a '95. I think it was the '95 that was press-on.
