05-26-2016, 09:24 PM | #1 |
Question about OEM frame number stamping
I have a frame that I purchased and was trying to identify what year it may have been originally. There are numbers stamped into the side of the rails that appear to be a part number, either GM or supplier that stamped out the frame rails for GM. However, under the part number I found what appeared to be a date 10 6 79 - frame looks for all the world like a 67-72 frame, but if that is a date code it wouldn't be a 67-72.
On top of the frame rail just behind where the steering box bolts in is another number with about 6 or 7 digits and one letter - is that the serial number / vin number?? Is that number keyed to vin on truck cab from factory? Any thoughts, suggestions, ideas on who to check with?? Thanks in advance. Jay |
05-26-2016, 11:12 PM | #2 |
Re: Question about OEM frame number stamping
Ending of serial number is stamped on top left flange near steering box .
05-26-2016, 11:26 PM | #3 |
Those are the last 8 characters of the VIN. The number before the letter is the last number of the year.
05-26-2016, 11:31 PM | #4 |
On Chevys in the 67-72 time frame the partial VIN was generally stamped into the frame's upper left flange at the steering box and often under the cab.
Look for eight characters like this example: 9 year B plant 800001 unit serial number There are a number of threads to be found on this if you use the site search.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-27-2016, 10:47 AM | #5 |
Those replies answer my questions - Thanks so much for taking your time and sharing your expertise with me. Jay
